Safe to remove door edge guards?
Old Aug 7, 2011 | 09:40 PM
SimpleFit's Avatar
I bought a CPO 2010 Fit Sport a few months ago, and it had these door edge guards already installed.
They don't look that bad, but I'm thinking I like my Fit would look better without them. I'm very careful opening my doors, so it wouldn't be something I'd miss.
I was wondering if anyone here knows if it's safe to remove them, or how to remove them?
Edit:
Here's a link to a page showing exactly what door edge guards look like, in case you're not familiar with them.
Just worried about messing up my paint.
Thanks
Old Aug 8, 2011 | 07:00 AM
Chad T's Avatar
Those should pull right off. They might leave a little glue behind which you should be able to remove with some WD40 or other mild solvent.
Old Aug 8, 2011 | 10:27 AM
malraux's Avatar
I would recommend not pulling straight out from the paint surface, as that's the most likely way to pull the paint off (not that I would worry about it in this case). That is, start at the top and pull straight down rather than pulling out.
Old Aug 8, 2011 | 12:40 PM
madsedan's Avatar
I removed mine the weekend I bought my 2010, looked like crap and mine were also around the wheelwells. Every dealer in my area installs them on every new Honda as part of a "care package" where they do that with nitrogen in the tires, and tint the windows and puts a $1,500+ add to the sticker, dealer profit item.
I gently pulled mine off starting at one end, then using goof-off and a microfiber I removed the adhesive.
I did it at the end of the day when the car was 100 degrees, makes it easier to remove.
Car looks so much cleaner once its off.
Old Aug 8, 2011 | 01:47 PM
sooznd's Avatar
warming the glue up a bit with a hairdryer might make removing easier
Old Aug 8, 2011 | 05:21 PM
^^ yah you can do that or just pull on it on a sunny day if you want. ive remove those moldings on previous cars. they are ugly for sure.
Old Aug 8, 2011 | 07:56 PM
Krimson_Cardnal's Avatar
Edit:
Thanks
Pull gently - start from one end. A few hours in the sun is easy to find - helps. All will be fine.
Old Aug 9, 2011 | 10:48 PM
SimpleFit's Avatar
Thanks a lot guys!
Some great answers. Especially heating it up.
Will try removing them this coming weekend and post results.
Cheers, SF
Old Aug 15, 2011 | 01:16 AM
SimpleFit's Avatar
Update: I removed the guards yesterday. It was a little time-consuming (40 min) removing all the leftover sticky tape, then using goo-gone to remove the remaining adhesive residue.
But now my Fit Sport looks sportier
I noticed I have the same kind of black edge trim along the wheel arches.
Do you guys with Fit Sports have this too?
-Or was this part of my dealer's edge guard add-ons thing?
Thanks
-SF
Old Aug 15, 2011 | 05:04 PM
buckyfit's Avatar
Do you guys with Fit Sports have this too? -Or was this part of my dealer's edge guard add-ons thing?-SF
No, the edge guards do not come standard with Fit Sport. They are dealer addons.
Old Aug 16, 2011 | 10:00 AM
^^ +1 wat bucky said.
it's a stupid add on some dealers put in there to make you pay more for your car. my cars definitely do not have them.
when i buy my car i test drive the exact car i purchase. i make sure the one does not come with these non-sense crap.
cnordt24
Jun 1, 2017 04:16 PM
Namae Kana
Jul 28, 2015 05:00 AM
Ameise
Jul 23, 2015 03:51 PM
lowkeymods
Aug 3, 2013 03:59 AM
bugzlyff
Feb 19, 2012 02:58 AM
