Electrical help
Old Oct 3, 2011 | 04:22 PM
B-Blue's Avatar
Electrical help
OK, I'm trying something here. I want to replace the stock hazard light with another type of push button. But I know squat about electrical. So these are the specs for the switch:
Specs:
  • LED is rated for 3 / 5 / 12v Input. Higher voltages are not tolerated
  • Terminations: /28 (2.8mm tabs)
  • Switching: S.P. Push to make, tactile S.P. / Latched Switch
  • Max. Rating: 50mA, 24V d.c. switch
  • Contact Resistance: <100m§Ù
  • Insulation Resistance: >103 M§Ù
  • Dielectric Strength: Contact to Panel >2.0kV
  • Contact to Contact 1500V Contact
So from what I can tell the LED will do just fine with the 12V supplied from the car. I was thinking of adding a fuse just to keep it safe for the LED. But I'm not sure about the switch, will the switch get killed because of the amps? I just don't know so I'm reaching out to someone with experience.
Old Oct 4, 2011 | 11:11 AM
Steve244's Avatar
Specs:
Assuming these are the specs for the replacement switch, the problem is we don't know the specs/requirements for the existing emergency flasher switch. There are also the physical characteristics of the switches we know nothing about: how many poles, does it latch on, etc...
but... 50mA at 24V is 100mA at 12V. This is not a very robust switch (1amp is 1000mA). Your car will run at 14+ volts with the engine running (could be a problem). Just for comparison, the dome light is probably 1amp @12V (12watts). What is the switch made for? Desktop?
Old Oct 4, 2011 | 12:40 PM
B-Blue's Avatar
yeah, it's for a desktop pc. I would think a resister might work to bring it down to 12v? But then will the turn signal lights get affected?
Old Oct 4, 2011 | 12:44 PM
Steve244's Avatar
Even if it fits, this switch is not appropriate for automotive use. Sorry.
Old Oct 4, 2011 | 01:00 PM
B-Blue's Avatar
Yeah, well thanks for the help. JDM switch it is then.
James Butler
Aug 15, 2018 11:49 PM
Macswfc
Dec 31, 2015 08:00 AM
Codi
Sep 30, 2012 08:30 PM
stock0891
Jan 28, 2011 04:27 PM
kenmei
Jan 6, 2011 08:35 PM
