Honda Fit keylock problem
Old Oct 12, 2011 | 04:03 PM
hondakypster's Avatar
Smile Honda Fit keylock problem
Hello,
Car: Honda Fit 7/2002 (right hand drive), automatic
Something must have happened and I just can't insert the whole car key into the driver's door to open it. Something is blocking my key from going all the way in. Only way to open the door is to use the remote-control.
What could be the problem?
Does the whole mechanism need replacing?
plz help.
cheers
kyp
Old Oct 12, 2011 | 05:08 PM
pauljazz's Avatar
You need to replace the cylinder door barrel.
I have replaced the drivers barrel on my 2002 Jazz and and it has gone again.
Old Aug 28, 2012 | 07:45 PM
dll932's Avatar
First try squirting a LOT of WD40 into the keyhole, then see if you can insert the key. If you can, work it in and out a few times. If you can't, take it to a locksmith and have him look at it. There may be something stuck in the keyway.
Old Dec 11, 2012 | 03:57 PM
Mempachi's Avatar
i hear you can squeeze some graphite powder and it.. this will help ease the key into the hole.
Old Dec 15, 2012 | 09:10 PM
dll932's Avatar
Not as well as WD40 or TriFlow. Also, graphite won't repel moisture-and it's messy.
hangout
Dec 7, 2017 12:21 PM
komark
Jul 7, 2016 08:41 PM
Vince_TB
Oct 24, 2012 02:56 AM
manic_monkey
May 29, 2012 12:34 PM
JahJahwarrior
Jul 4, 2010 12:57 AM
