Sponsored by:
Sponsored by: CARiD
VERY loud FR wheel noise at low speeds only in cold weather
Old Dec 26, 2011 | 03:08 AM
debudebu's Avatar
Hey, I have a strange problem that I can't find any information about. This is my first winter in Alaska with my 07 fit, and the right front wheel is making a very loud rubbing, creaking sound only when the temperature is below 25F or so, and only when starting from a stop. The sound goes away after i reach 10mph or so. if i'm going 30mph and i accelerate quickly, the sound will show up for a split second and go away again. I'm pretty sure the sound is associated with the turning of the wheel since it changes as the wheel turns faster. It doesn't seem to be affected at all by the brakes or steering.
Does anyone have any idea what the problem might be?
Old Dec 26, 2011 | 10:37 AM
SilverBullet's Avatar
I had the same problem too. At first I thought it was the clutch, then I thought it was the road. The dealer could not find the problem except to realign the front end. I think it has something to do with how the car got tied down being shipped from Japan. It ended ruining the tires but l left them on anyways.
Old Dec 26, 2011 | 10:40 AM
Santiad's Avatar
check your components there: most problems there are only usually heard at slow speeds and usually sound like grinding and creaking:
ball joints, wheel bearings, even dragging brakes or caliper issues....
have you had any work done recently involving the removal of the hub asssembly?
Old Dec 26, 2011 | 06:15 PM
debudebu's Avatar
thanks for the reply. it could be a ball joint or wheel bearing... although it's strange that it would show up only at cold temperatures. has anyone else experienced this noise?
Old Dec 26, 2011 | 06:17 PM
debudebu's Avatar
so you never figured out what the problem was? do you still get the loud noise when the temperature drops?
Old Dec 28, 2011 | 01:26 AM
jazz_honda's Avatar
i'm experiencing this now...but mine..the noise gets louder when i drive 60kph and above...100kph is really noisy humming sound...i think its the wheel bearings due for a change...120km in my odo...but i called the honda dealer for an appointment and was shock with the price of the wheel bearings front and rear.
Old Dec 29, 2011 | 01:08 AM
debudebu's Avatar
ok. for anyone reading this thread, i think i figured out my problem. after driving the car yesterday and getting the same loud creaking noise when starting from a stop, this morning i checked the front disk brakes and noticed that the right one was a bit rusty and the left one was clean. this got me to thinking that the creaking sound might be the front right brake binding to the disk--stuck on, in other words. my theory is that the cold temperatures are causing my (probably water infused) brake fluid to freeze up, thus expanding and making the caliper close just enough to grip the rotor at low speeds.
i just finished bleeding my brakes, using information in this forum and on youtube, and i will update in a few days.
Old Jan 4, 2012 | 07:27 PM
debudebu's Avatar
it's been five very cold days (-5 F) and the noise has not returned, so my theory was correct, and the brake fluid change has fixed it.
zrkd51
Feb 4, 2016 08:57 PM
zippy007
Jul 14, 2013 03:26 AM
single_digit
Feb 14, 2013 11:56 AM
pearl
Sep 26, 2012 08:30 AM
chilow
Apr 24, 2012 10:00 PM
