Another GD water thread
Old Jan 6, 2012 | 06:14 PM
CartridgeBot's Avatar
Angry Another GD water thread
Hi guys;
I've got an 07 Fit Sport, and I've got the "classic" water in the rear, driver side footwell.
Last year, when I first noticed this, I took apart my door panels and used some aluminum tape to seal the plastic barrier, which I hoped would solve the problem.
No bueno. More water in the footwell. Furthermore, this time around, I've noticed water pooled in the spare-tire well -- Water seems to shift between the two depending on how I'm parked.
I'm at wits end. Local quotes are around $200 to even start doing a drip test, let alone any fix, and I'd rather not just trade the car in to be rid of it because I otherwise adore it.
Can anyone else give me a direction (explained like I'm 5, if you would) to look? I've gone over the car with a hose and I'm not seeing anything obvious.
Thanks.
Old Jan 6, 2012 | 09:46 PM
willy65000's Avatar
How about having a friend sit in your back seat while you run the car through a car wash.
Old Jan 6, 2012 | 10:55 PM
GAFIT's Avatar
"Another" "classic" thread? I didn't know this was a problem. Is this spam from a ONE time poster?
Old Jan 6, 2012 | 11:28 PM
kelsodeez's Avatar
UNBANABLE
its a real problem. most GD3's leak into the rear footwell.
Old Jan 6, 2012 | 11:44 PM
GAFIT's Avatar
I hadn't heard of it. My guess would be that it's leaking between the two doors and seeping down inside the rear door. Just a guess...
Old Jan 7, 2012 | 12:15 AM
kelsodeez's Avatar
UNBANABLE
actually the only GD3's that are affected are early model 07's. there was a thread on it from some guy in europe back in the day and i believe that he found the water was coming in from the sheet metal seam under the rear, left hand side seat.
i had the same problem but ever since ive been parking my car on level ground, it hasnt been leaking.
Old Jan 7, 2012 | 03:42 PM
I think I managed to actually narrow down where it is. As I said, I'd patched the doors already. I popped off the plastic covers over the shock strut mounts and found that on the drivers side, I had water spraying in whenever the shock compressed. I'm not sure at the moment if it's coming in around the rubber gasket, or if it's the weld on the cup. I figure I can JB-weld around the cup seams, and clean up that area. I'll get some pictures as well, just so I'm not called out as being a troll.
Old Jan 7, 2012 | 04:30 PM
Here's a couple of pictures:
Linking them because they're large.
https://i.imgur.com/sZ85k.jpg
https://i.imgur.com/VANM4.jpg
Old Jan 7, 2012 | 06:33 PM
GAFIT's Avatar
Troll. Oh, wait, I wasn't supposed to call you that Sorry for the name calling and good luck on the repair. What is all of the white stuff in your pictures?
Old Jan 12, 2012 | 05:03 AM
supremeXorio's Avatar
had the same issue with my 05 dc5 and same with my 07 gd3-___-,the water makes its way to where the spare is and chills
Old Mar 1, 2012 | 02:10 AM
jeffreytrip's Avatar
Man, I feel your pain!!! I got water leaking on the driver side floor, the rear passenger door behind the driver seat, the trunk spare tire well, and the back right taillight cover!!!! Shit!!!! Fuck it!! After reading everyone's water woes...I'm just gonna buy that spray on rubber seal stuff from home depot on my 2007 Honda Fit.
Old Mar 8, 2012 | 10:34 PM
Virrdog's Avatar
Wow, I had no idea what this was talking about until I saw the pictures with the strut mount cover.
I was wondering what my wife had spilled in the back area so quickly...
Any consensus on how to take care of this? Mine seems to be a small amount, so maybe damming the water by the strut top mount so it can just drain back out?
Old Mar 9, 2012 | 12:54 AM
Virdog, I actually took the entire day to figure it out. On the right front door and the left front door right under the speaker, the seal is not big enough...therefore water leaks in. So those are automatically two spots already. The other one is the seal in the antenna. It leaks a little bit of water.
Old Mar 9, 2012 | 07:24 PM
Cat's Avatar
Cat
Never had any issues with my GD3 having this problem. Glad you found out what was going on.
Old Aug 22, 2012 | 04:47 PM
blue2008base's Avatar
look for cracks in the top corners of the rear hatch its leaking from there down between the panels
Old Aug 29, 2014 | 01:30 AM
F-it good's Avatar
easy fix
I had this problem with my 08 base fit. To solve the problem but it won't be the prettiest fix. Use duck tape, whatever color you choose. Open the rear door, duck tape above the weather strip covering the whole top across and that's it. I don't have my 08 base anymore but I did the same to my 07 sport Fit, still haven't had anymore water problems
Old Sep 23, 2014 | 05:50 PM
Paulo107's Avatar
Got this problem happen to me Sunday when we had a crazy rain storm and water is behind the frt passenger seat under the rear seat. My car stunk like dirty feet Monday morning.
Old Sep 25, 2014 | 01:14 AM
JaySmith's Avatar
For those affected with water getting into the vehicle, there is a TSB that addresses one of the issues.
The other more common issues tends to be the seal around the antenna, or the hatch seal.
However, the most common issue that allows a lot of water into the spare tire well, which I too was affected with, tends to be small cracks between the roof line and the quarter panel line. You'll need to remove the two long black roof rail seals.
https://www.fitfreak.net/forums/1st-...ml#post1192520
Dsardone
Jun 23, 2021 01:10 PM
geepondy
Mar 30, 2014 07:53 PM
08fithappy
Feb 3, 2011 08:20 PM
Cyphron
Jan 15, 2011 11:49 PM
coralaholic
Sep 18, 2009 11:37 PM
