Replace balljoint or LCA?
Old Mar 15, 2012 | 05:36 AM
Bman98SL2's Avatar
Hi folks,
I think the passenger side balljoint is going. I've done some searching and can't find much on balljoints. Can I remove the LCA and press in a new balljoint, or am I better off replacing the LCA assembly? I see that NAPA has listings for both (of course the balljoint is 25% the price of the LCA assembly).
My Fit is an '08 (non-Sport) with 60k miles.
Thanks,
Bman
Old Mar 18, 2012 | 08:25 AM
Bman98SL2's Avatar
Sounds like balljoint replacement is not very common?
I guess I'll go the conservative route and replace the LCA assembly.
Bman
Old Mar 18, 2012 | 09:32 AM
apexanimal's Avatar
if you can get the ball joint seperately, save yourself the money and just replace that...
Old Mar 18, 2012 | 01:37 PM
Potenza's Avatar
I would just replace the ball joint if you're only at 60k.
If you had higher miles I'd say replace the whole arm; at this point that isn't necessary. It's strange for a ball joint to go bad that soon, unless the boot was ripped.
Old Mar 19, 2012 | 10:20 AM
Bman98SL2's Avatar
Thank you for the responses.
I'll try to find someone who can press the ball joints out / in. I travel some rough roads (it's Cleveland after all) and don't slow down much for railroad crossings, so maybe that is catching up with me. I don't know for sure that it is not a tie rod end, except I do not perceive any play in the steering. I'll get the car up and investigate further before I replace anything. Interesting to hear that balljoint failures are rare. I guess that's why I didn't find much when I searched!
Bman
doctor J
Oct 1, 2017 08:37 PM
Vash
Sep 8, 2016 06:10 PM
towpackagefit
Sep 2, 2016 12:47 PM
Santiad
Jul 26, 2015 03:35 PM
Phsion
Mar 26, 2014 07:38 AM
