Drive shaft too long! HELP!
Old Jun 19, 2016 | 12:43 AM
towpackagefit's Avatar
Hey Fellas,
Putting the Fit back together after control arm, wheel bearing replacement. Drivers side went well, passenger side not so much. I am not able to align the ball joint due to the drive shaft seeming to be too long. After hours of rotating and trying to get the thing back to normal still having no luck here. Any recommendations would be greatly appreciated. I am new to the forum and I searched drive shaft axle related issues. Someone mentioned there are threads posted about this issue under the "suspension section."
Thank you!
Old Jun 19, 2016 | 11:29 AM
ezone's Avatar
When you took it all apart, did you accidentally pull the inboard CV joint apart internally?
You will either need to manipulate its rollers back into their slots by squeezing them through the rubber boot, or take it apart to figure out how to get the rollers back into their slots, or replace the axle.
Old Jun 21, 2016 | 07:39 PM
doctor J's Avatar
Or, perhaps, the intermediate shaft bearing came out from the bracket a bit?
Pictures please!!...
Old Sep 2, 2016 | 12:47 PM
Texas Coyote's Avatar
I nearly had an anxiety attack when that happened while I was helping another Texas Freak install coilovers on her Fit. Ten seconds or so later all was well..
TexasWonder
Dec 13, 2017 01:07 PM
tekmcleod
Oct 26, 2016 02:38 PM
RandomKoko
30
Sep 14, 2012 06:02 PM
jnesselroad
May 28, 2011 08:10 AM
