80k Mile Maintenance
Old Sep 4, 2012 | 12:38 PM
madtodaimax's Avatar
My 2008 GD recently broke the 80k mile mark. I dont always have time to do regular maintenance (I'll try and do the oil changes when the maintenance minder prompts me). I have a vacation coming up and I'm wondering if there is any maintenance that I should get out of the way now. It'll be a few months (probably another 10-15k miles) before I can do some serious work again. Front brake pads were changed about 20k miles ago. Other than that, I havent done anything else really.
Also, if I want to switch to synthetic, what weight should i go with and do I need to do anything special with switching/breaking in after i switch?
Old Sep 4, 2012 | 12:43 PM
NIGHTHAWKSI's Avatar
nothing major until 100k
until then...
change tranny fluid
top off all fluids
check brakes
oil changes
change air filters
at 100k...
change spark plugs and get a valve adjustment.
and all normal maintnence items
no problem switching to synthetic. use teh same weight that you use for regular oil.
Old Sep 4, 2012 | 12:49 PM
^For the tranny fluid.. I've got a MT. Should I just go with the Honda stuff or is there another brand that will be better?
Old Sep 4, 2012 | 02:23 PM
dtfdanyo's Avatar
Honda MTF (tranny fluid) is awesome. I would recommend it
Old Sep 4, 2012 | 02:49 PM
penzoil synchromesh is my choice. made shifts alot smoother
Old Sep 4, 2012 | 11:01 PM
doctordoom's Avatar
Supervillain
Change and bleed the brake fluid if it wasn't changed with the front brake pads, or if it's been a few years since it was changed.
littleblackcar
Feb 25, 2018 12:47 PM
StickSticklyHere
Nov 16, 2015 09:03 AM
submart
Sep 30, 2014 10:59 AM
hondafitgow
Sep 3, 2012 10:26 AM
hqly
Jul 5, 2009 09:23 PM
