Emergency Brake Troubles !!!!!!!
Old Mar 4, 2013 | 01:20 AM
chinkyy's Avatar
Recently I noticed that my E-Brake light does not turn on when the E-Brake is engaged. However, at start up the E-Brake light flashes along with all the other warning/symbols. The E-Brake works fine though. I'm just a bit worried that the light doesnt pop up. Anyone know what could be the problem??
Old Mar 4, 2013 | 09:32 AM
DrewE's Avatar
It sounds like it's the switch in the emergency brake mechanism or possibly wiring to it. It's not a terribly important thing to worry about IMHO—the main purpose is to prompt you to release the parking brake before you drive off—and it should be relatively simple and inexpensive to fix.
I'm assuming, from your description, that the brake light doesn't continue to flash or illuminate after the car is started up. (If it does, you may have low brake fluid or some other fault in the brake system that should be checked out.)
Old Mar 4, 2013 | 10:37 AM
Doug Just Doug's Avatar
I don't know for sure, but I'm guessing there is a plunger switch somewhere in the e-brake linkage. If so, perhaps it's gummed up; a little shot of WD-40 or contact cleaner might do the trick.
honestrands
Oct 15, 2021 10:53 AM
daves007
Apr 26, 2015 07:11 AM
Wolfvision
Apr 5, 2011 12:48 PM
Sera
Mar 19, 2007 12:22 AM
Jimmy101
Feb 21, 2007 08:22 PM
