3000 - 3500 RPM vibration!
Old Apr 3, 2013 | 11:32 PM
appleica's Avatar
Hey guys,
I recently replaced my passenger side axle, transmission fluid, and I'm having some really odd issues with my car!
I torqued that big nut on the wheel hub a lot more and it seems to helped a bit to reduced the vibration but...
Transmission fluid was changed at my 90000km with genuine honda transmission fluid and the shifting is smooth.
The car has a very odd vibration at exactly 3000rpm only when the gear is engaged. I've tried these scenarios:
1. Rev the engine at idle to around 3k-3.5k, nothing happens
2. Coasting and I rev the engine with the clutch in around 3k-3.5k, nothing happens...
3. In any gear, bring it up to speed with the revs at around 3k-3.5k exactly, I hear the vibration and FEEL a vibration, also it almost feels like the car is struggling ever so slightly but the rev's keep coming up...
4. I've checked the heat shield on the headers, nothing changed
5. I've installed a new air filter, nothing changed
I've super baffled. is my transmission going bad? It's a manual gd3 at 92000km's
Any ideas?
Old Apr 4, 2013 | 05:28 PM
Doug Just Doug's Avatar
Does the vibration remain above 3-3.5K or does it go away beyond a certain RPM?
Old Apr 4, 2013 | 07:04 PM
13fit's Avatar
All motors have a resonance rpm. It has to do with the intake manifold and exhaust design.
I notice this as well. It was reduced slightly when I modified my intake, aka, removed the bottom half. This exposes the filter to more elements, but it does remove the bottleneck that is a small rectangul for airpassage under the filter.
And the fit sounds much better between 3-4500 rpms
Old Apr 9, 2013 | 03:23 PM
knm345's Avatar
Originally Posted by appleica
Hey guys,
Any ideas?
try checking the alignment
Old Apr 11, 2013 | 09:45 AM
appleica's Avatar
The vibration is only at 3-3.5k in any gear...
Also if i'm in 3rd gear, down shifting into 2nd gear and i land on 3k rpm it struggles a bit to pull.
I guess I might Seafoam it.
Old Oct 30, 2013 | 09:20 PM
Antpwny's Avatar
Did you ever resolve this issue? How did you do it?
Old Dec 16, 2013 | 10:09 PM
mikelowell915's Avatar
I have the same problem and it happened after i replaced the axle as well, shortly after my throw out bearing went bad, not sure if the 2 problems are related, but on top of that the axle seal is now leaking, so next big project for me is a clutch kit, and axle seal, i will let you know if the vibration goes away when i replace the throw out bearing. Let me know how you make out with yours...
Old Dec 17, 2013 | 11:59 PM
D429302's Avatar
are you guys replacing with OEM axles or aftermarket? ive seen countlesss times of vibration under load issues caused by aftermarket axle.
Old Dec 23, 2013 | 08:40 AM
I have always used AutoZone parts on my Hondas and never had an issue, I go through axles a lot the way I drive, especially in the snow, I guess it could be an aftermarket part issue I never thought of that, I am almost certain it is duralast that made the axles hmm... There is a lifetime warranty on those...
Old Feb 27, 2020 | 09:45 AM
King Tai's Avatar
Hey guys,
Any ideas?
have you come into conclusion to solved? I got similar issue as you. Please advise...
Old Oct 12, 2021 | 04:58 PM
davidsavop's Avatar
No relationship to axle or clutch
Just wanted to let you know…
The vibration as you described it cannot be in the clutch or axles, as it relates directly with your engine speed at 3000rpms. Your axles and clutch rotations are different speeds in each gear, so they would vibrate at different engine speeds in each gear. If the engine vibration is consistent, regardless of the gear you’re in, then you have an engine problem or computer problem (the engine controller). Just trying to help.
Old Oct 12, 2021 | 05:28 PM
davidsavop's Avatar
Hey guys,
Any ideas?
Did you ever resolve this issue? My son’s 2018 Civic has identical issues and he hasn’t been able to find it. Would appreciate your solution if resolved. Thanks!
phoenity
Oct 1, 2018 03:10 PM
bigsmitty
Oct 8, 2015 10:45 PM
GinoLicious
Feb 14, 2014 10:31 AM
ruknight4ever
Nov 30, 2008 08:00 PM
bozerwong
Oct 16, 2007 10:31 PM
