Water Leak
Water Leak
Anyone have some water coming in the rear hatch area? I live in S FL so it rains. Anyone have this issue and know what to change. It a little, but these things can get worse and we are in the rainy season.
Thanks
Thanks
Yep, been there done that!.
Mine was coming from the roof body seams at the very rear of the roof. The water would run down inside between the panels into the spare tire area.
I have pics if you want to see them. I used clear silicone and put it all over the factory seam sealer that you will find under the trim strips that run along the roof of the car. Take them off and you will probably see that the factory body seam sealer is cracked.
CasualFitOwner
Mar 30, 2013 01:32 PM
Raaaaaaaaaay.
24
Mar 11, 2009 04:47 PM
