Rightside rear power lock malfunctioning
Old Feb 19, 2015 | 04:52 PM
Eric Moss's Avatar
The rear right side power lock on my '07 Fit Sport is not responsive. Using the remote or the door lock button does not work. It has to be manually locked and unlocked. I checked the fuses and they look good. Any ideas? Thanks.
Old Feb 19, 2015 | 06:58 PM
Goobers's Avatar
Well, actuator could've failed.
A way to test to see is to open up the rear door panels (both sides), swap the actuator to the working side and see if it triggers.
If it doesn't trigger on the working side, then replace with a new actuator and it's done.
If it does trigger (conversely, the working actuator doesn't in that side), problem is somewhere up the line... Gets harder from here on out since someone will need to diagnose it further.
gkitf16
17
May 4, 2026 07:57 PM
dongetti
Jan 22, 2024 10:05 AM
dhoran
Sep 29, 2020 09:28 PM
Fitman09
Nov 30, 2015 05:01 PM
jbolanos
May 1, 2008 06:43 PM
