GK5 Fog Light Housing Removal?
Old Apr 25, 2015 | 08:19 AM
IzunaDrop247's Avatar
Does anyone know how to remove the GK5 foglight housings?
I tried prying it out from the outside edges with a flathead screwdriver, but it was still really tight on there after freeing up 2 clips.
I don't want to damage the paint trying to force it while trying to figure out how it comes out.
Is there a side I should start with first?
Old Apr 25, 2015 | 09:45 AM
ROTTBOY's Avatar
Originally Posted by IzunaDrop247
........how to remove the GK5 foglight housings?.........
To remove them properly, the front bumper must be taken off. REad the FACTORY instructions for installing the OEM sports grill accessory. It will provide all the steps.
Each foglight housing has 8 clips. Getting to each of them for complete removal is best done from the inside of the front bumper.
Should you decide on pursuing this route, consider the ff:
- have a thick blanket or rug to rest the removed bumper
- this is the best time to upgrade the OEM "beep-beep" sounding horn
Good luck and let us know how your project turns out.
Old Apr 25, 2015 | 09:54 AM
Originally Posted by ROTTBOY
To remove them properly, the front bumper must be removed. REad the FACTORY instructions for installing the OEM sports grill accessory. It will provide all the steps.
Each housing has 8 clips. Getting to each of them for complete removal is best done from the inside of the front bumper.
Thank you! Good thing I stopped before I would have done something regretful. I will work on removing the bumper.
REPLY: Yr. welcome. BTW, liking the nippon theme on your GK. Very appropriate!!!! Keep posting pics. - rttby
Old Apr 27, 2015 | 01:18 PM
ROTTBOY's Avatar
Pics of Garnish tabs
Old Apr 27, 2015 | 03:02 PM
I got them off. Thanks! I was able to tint the fog lights yellow.
Old May 2, 2015 | 04:15 PM
andre181's Avatar
You can remove them very easily without removing the bumper.
Use a SOFT plastic trim tool and pry starting on the outside, and once you get those clips to pop, start at the top and work your way to the inside. Once you get enough clips to pop that you can get your fingers between the fog light shroud and the actual light itself, you can pull it the rest of the way off gently, while prying along to bottom.
Go slow and you won't break anything.
I've done it this way 3 times on both sides since I've owned the car and never had an issue.
Old Mar 10, 2016 | 10:30 PM
2015FITEX's Avatar
how did you tint them yellow ?
and the links dont work....can anyone make them work
i would like to do what you have done
Old Mar 11, 2016 | 10:01 AM
Myxalplyx's Avatar
You are correct but I still ended up breaking one of the clips on my driver's side. It was being stubborn, it was cold out and I was in the moment. That's all it took! *&^%
StormSilverGD3
Dec 2, 2021 10:39 PM
david518
33
Jan 10, 2020 11:54 AM
bim27142
Nov 24, 2016 01:49 AM
666fit666
Jul 1, 2016 10:41 AM
PHNTMONE
Feb 18, 2015 01:43 PM
