GE8 DIY Guildeline - Illuminated Auto Folding Side Mirror Switch Conversion
Old May 14, 2015 | 07:51 AM
ViRStephen's Avatar
*Disclaimer: I'm 100% sure be NOT endorse, recommend, encourage or take any responsibility for the outcome result of someone else doing this conversion. Your conversion at your own risk!*
If you insists for conversion means you're AGREED the disclaimer as above.
These was done by me on my JAZZ GE8. It should be suitable for USDM JAZZ or FIT...
Please follow the guideline on below comment step by step:
1. Remove meter hood
2. Remove 2pcs screws
3. Left=Jazz/Fit switch, Right=CRZ switch
4. Remove the claws as show by red arrow to separate the switch from cover
5. Position of claws which can find on top & bottom
6. Switch separated from cover
7. Front View : Left=CRZ switch, Right=Jazz/Fit switch
8. Rear View : Left=CRZ switch, Right=Jazz/Fit switch
9. Create a power cord, earth wire & illumination wire
10. Interleave to the socket terminal, red arrow is illumination wire, blue arrow is earth wire
11. Diagram of socket terminal, Pin 10 is illumination wire, Pin2 is earth wire
12. Wedge the illumination wire to any illuminator line such as VSA or ECON from Power Fuse Box, the earth wire connecting to the Addiotional Ground.
13. Enjoy the illuminated Auto Folding Side Mirror Switch
Coolmint
Oct 11, 2014 12:39 PM
boyito
May 25, 2012 03:20 AM
caliban10010
Aug 28, 2010 06:51 AM
Mugen_Dom
Aug 7, 2007 01:26 PM
