Sponsored by:
Sponsored by: CARiD
Wiring for DRLs
Old Nov 15, 2015 | 02:34 PM
esnave09's Avatar
Wiring for DRLs
I was looking into doing a projector retrofit and LED DRL install on my Fit and needed to find out the best way to wire the DRLs in. I know that they are just a lower-output of the high beams, but I need to find out where the control for that is. I have them disabled right now by pulling out the fuse, so going from the wiring behind the fusebox would be my first guess. Anybody know anything else about this?
BTW, here's a link to what I'm planning it to look like (roandyo's suggestion). https://www.fitfreak.net/forums/3rd-...t-options.html
Old Nov 15, 2015 | 03:46 PM
ezone's Avatar
High beam DRL operation is controlled by the MICU inside the interior fusebox.
I'm not familiar enough with those to tell if you would need to use DRL decoders or not.
Googled DRL LED decoder and got this result
How to Convert High Beam DRL to LED Lights
Old Nov 15, 2015 | 04:40 PM
xxryu139xx's Avatar
just tap a fuse that turns on with ignition and run a line to the drls.
Old Nov 16, 2015 | 10:25 PM
esnave09's Avatar
If I were to just tap a fuse and run a line, I would be using the standard DRLs too wouldn't I? I don't want to use those (they look stupid, imo), so just the LED strips.
Old Nov 16, 2015 | 10:30 PM
xxryu139xx's Avatar
no just leave the fuse for the drls out. thats how i have mine setup so it doesnt burn out my projectors. my drls are my demoneyes although u cant see it in the daytime. they turn on with the car and off with the headlights. i use my v3 leds as my drls if i want to along with my halos with a flick of a switch.
Old Nov 16, 2015 | 10:55 PM
esnave09's Avatar
Interesting. I'll have to look into that! Although I'm hoping the LEDs won't be on with the headlights, since I'm gonna have blue headlights and yellow fogs.
So basically I'm looking for the function of the DRLs, just a different look to them.
Old Nov 16, 2015 | 10:56 PM
xxryu139xx's Avatar
get a relay. i have my demon eyes and halos to turn off when the headlights turn on.
Old Nov 16, 2015 | 11:29 PM
esnave09's Avatar
Good point. Relays always seem to be the answer, and I never think of that first. lol
FitBiscuit
Sep 21, 2017 07:57 AM
justalilbit
May 5, 2017 01:58 PM
mr_RogerWill
Nov 2, 2014 04:57 PM
QWIKVTEC
Nov 5, 2013 06:49 PM
rickycbrjazz
Mar 15, 2011 01:15 PM
