Help! Bagged my Fit now EPS and steering issue
Old Jan 24, 2016 | 03:53 PM
JenR's Avatar
Over the past week I have been converting the stock suspension on 2009 Honda fit to AccuAir management with ViAir compressors. In the beginning stages of taking out stock, I accidentally left the CV axle/wheel assembly hanging on driver front side without support for too long and separated the drive shaft and inner CV joint. Got the axle reseated and back in. Put in the struts, attached everything. All is good with the air management and compressors but something has happened that has caused EPS light to come on, steering is stiff and sticks, and there is a rubbing/clicking kind of noise when I turn (even if the bags are full and with plenty of clearance). thoughts??
Old Jan 24, 2016 | 05:00 PM
xxryu139xx's Avatar
did u damage your abs sensor? maybe you didnt unclip it and fubared it.
Old Jan 24, 2016 | 05:13 PM
JenR's Avatar
ABS was disconnected at beginning of process. First time on ground when testing the bags and turning car on I failed to reconnect. It of course is connected now. Would this need to be reset?
Old Jan 24, 2016 | 05:34 PM
xxryu139xx's Avatar
did u get the error when u failed to reconnect? try unplugging the battery for 10 mins and see if the error comes back.
Old Jan 24, 2016 | 05:52 PM
JenR's Avatar
Going to try this. Unsure if error came when testing bags before connecting abs back. Didn't drive it then. Will post in a few on result.
Old Jan 24, 2016 | 08:09 PM
JenR's Avatar
Unhooked battery while I tightened the strut towers. Rubbing noise is gone by tightening those. But still have no power steering and still like a clicking noise when turning (mainly when I turn left)
Old Jan 25, 2016 | 04:47 AM
krunk13's Avatar
Tierods maybe
Old Jan 25, 2016 | 08:07 PM
JenR's Avatar
Had an obd ran and getting code U0131: Lost Communication with Power Steering Control Module. Doing research now, but still not sure where the issue may be.
Old Jan 25, 2016 | 08:12 PM
xxryu139xx's Avatar
check ur fuses first
Old Jan 25, 2016 | 08:16 PM
JenR's Avatar
will do. thank you. will post back with result
Old Jul 28, 2016 | 03:05 PM
Jaime Gonzo's Avatar
Result
Did you ever fix this problem?
Old Jul 28, 2016 | 11:02 PM
ezone's Avatar
There is a warranty extension (mention bulletin # 14-058, or you had a letter from Honda but can't find it right now) that covers the repair of only two certain codes in the electric power steering system up to 10 years/150,000 miles.
Talk to your Honda dealership service department, have them check your VIN to see if it is in the affected covered group of vehicles, and have them see if that's the problem with your car.
Kristinb737
Apr 7, 2024 10:35 PM
JenR
Jan 24, 2016 12:28 AM
1toughfit
Nov 23, 2015 07:30 PM
RandomKoko
30
Sep 14, 2012 06:02 PM
bbarend
Jul 28, 2010 09:21 PM
