2010 Fit Radio
Old Jan 30, 2016 | 04:07 PM
Dexter38's Avatar
2010 Fit Radio
Please read entirety before commenting. Thanks!
Changed battery - got Radio Code from dealer - put in code - said "code error" - confirmed code w/dealer (3 times!), also confirmed code online. Followed a couple of pieces of advice from this forum. FINALLY got radio to come on - w/in 2 minutes it goes off - can only restart if car turned off, then on. Again, radio on for 2 minutes then goes off. At my wits end! Do I need to pull out radio to verify serial # is correct? This is so frustrating and a huge pain!!
Thanks for advice!!
Old Dec 20, 2017 | 06:37 PM
Troopercat's Avatar
Question Solution?
I hope you can share your solution with me!!? The same is happening to me.
Old Jan 9, 2018 | 08:07 PM
steve37's Avatar
OP is about 2 years old...thought I would try here anyway.
Found radio code in glovebox. Tried to enter it...no luck. First problem is my code contains 2 zero's. Where is the zero button on my radio (2010 Base MT)?? I have 1-6, but no zero.
The owners manual gives no details about the whole process.
Old Jan 9, 2018 | 10:57 PM
ezone's Avatar
You may have found a serial number instead of the unlock code.
Unlock code is 5 digits.
https://radio-navicode.honda.com/
Old Jan 10, 2018 | 09:55 AM
steve37's Avatar
Smile
Yes, you are right...Thank you!
The prev owner had put the 6 digit number on the owners manual. I thought it was for the radio...maybe a key code?
Looked and found the correct one on the side of the glovebox.
Radio works good now.
crash001
Jun 28, 2024 07:54 AM
Mister Coffee
Feb 7, 2019 06:00 PM
cici235
Jun 26, 2012 12:41 AM
mahout
Jun 4, 2011 08:17 AM
Lideusz09
Oct 9, 2009 05:41 PM
