Best 2007 & 2008 Headlight Buld
Old Feb 21, 2017 | 08:08 AM
JodysTransmissions's Avatar
We have a 2007 and 2008 Fit and we keep loosing headlight bulbs. These are the $50+ Sylvania or the less expensive Autozone bulbs.
What are you all using for bulbs for longevity? Is a Honda bulb recommended?
Thanks, Jody
Old Feb 21, 2017 | 09:20 AM
JackMan's Avatar
Do you have any condensation showing on the inside of the headlight? If there's water inside, that will blow the bulb if it comes into contact with the hot glass. When installing the bulb make sure you don't touch it with your fingers. Oil residue from your skin will bake onto the bulb glass and cause it to fail (eventually).
Honda bulbs are no different than the ones you've installed. There must be another source of why they're blowing.
My recommendation: check for moisture inside the headlight assembly first
Old Feb 21, 2017 | 11:07 AM
No moisture inside the lens housing and I knew not to touch the bulbs during installation. These bulbs seem to last about 5-6 months.
Old Feb 21, 2017 | 01:03 PM
JackMan's Avatar
I'm sorry I can't add anything more to this issue. 6 months seems a pretty crappy lifespan. You may just have bad luck with the filaments breaking? Hopefully someone with more knowledge than I have can chime in with something you can try. I installed a miniD2S projector retrofit in my headlights so I've been out of the halogen bulb universe for a while.
If it's not moisture/oil getting on the bulb, it may be bad luck, or vibration?
Old Feb 21, 2017 | 06:30 PM
dwtaylorpdx's Avatar
Osram bulbs work the best in my jeep which is a kidney pounding machine, the expensive bulbs don't last for more than a couple months.. (PII and the High end Sylvania's)
Old Feb 22, 2017 | 07:41 AM
"miniD2S projector retrofit in my headlights"
Is this an easy conversion? You have been most helpfully by answering my post, thank you!
Old Feb 22, 2017 | 10:13 AM
solbrothers's Avatar
have you gotten the headlight recall done? mine kept going out until i got that done.
also, my low beams dont work when it rains. only highbeams. i need to figure that out.
Old Feb 22, 2017 | 10:31 AM
This is a new recall that I have not heard about? Recall number?
Old Feb 22, 2017 | 03:48 PM
JackMan's Avatar
Hey Jody, the miniD2S projector retrofit is quite involved and requires disassembling the headlight. If you're content with your halogen lights (when they work), it may be in your best interest to keep them and not do a retrofit.
I wasn't aware there was a headlight recall, but if that's the case, check with your dealer and hopefully you can get some of the bulb cost back.. or a free set of light bulbs? Again, I'm sorry I can't be of much help beyond the obvious solutions of why it keeps blowing!
Morair
May 9, 2012 08:26 AM
sdiesel619
Oct 18, 2010 01:21 PM
Chazzlee
Dec 2, 2009 08:49 PM
crushbent
Apr 20, 2008 06:08 PM
FikseRxSeven
Jul 1, 2007 12:00 PM
