Honda Fit Trailer | Registering in CA
Old Jun 14, 2017 | 03:34 PM
airwicc's Avatar
So I've done a fair research about towing a trailer within CA state laws etc. But I need some real experience about how the process of registering it in CA goes.
I've read that I would need the MSO, the receipt, and VIN# when I register at the DMV. Correct me if I am wrong.
If any of you are curious it'll be a class 1 habor freight trailer(less than 2000 pounds). And I'll be towing a motorcycle around. Info would be greatly appreciated
Old Jun 15, 2017 | 01:13 AM
dwtaylorpdx's Avatar
They give you the MSO with the trailer from what I can tell. You have to ask though..
Old Mar 20, 2018 | 03:34 PM
GQ_Style's Avatar
I thought all the trailer hitches are mainly for bicycle carriers and not really to tow a trailer since the manual explicitly warned against trying to tow anything on the GD model. Has any tried? Safe to do it?
Old Mar 21, 2018 | 03:44 AM
hfelton's Avatar
you have revived a fairly old thread to ask a question that has been answered numerous times in other threads ... maybe try a search next time ?
afaict, there are plenty of folks who have towed using the usa-fit - and yes, they did it safely... if you want more info (like what extra equipment they might have added to ease the strains), try searching...
sorry to barge in, but im kinda snippy tonite...
Old Mar 22, 2018 | 02:42 AM
GQ_Style's Avatar
Nope nothing came up. "GD3 tow" "fit tow". Search is really not intuitive on here. Prove me wrong. Link me to one thread.
Old Mar 22, 2018 | 07:32 AM
hfelton's Avatar
challenge accepted, so i will document all my attempts (briefly) below...
1) as you mentioned, i went ahead and tried the single word --towing-- and got 496 results with nothing looking promising on the first-page of 25... hmm...
2) second try word --trailer-- and got 490 results, but on the first page i saw two threads that looked promising:
a - https://www.fitfreak.net/forums/3rd-...-2018-fit.html
b - https://www.fitfreak.net/forums/3rd-...-2018-fit.html
both of these titles contained the word --hitch-- so went ahead and tried a third search with just that one word... got 491 results and on the first page these further threads :
a - https://www.fitfreak.net/forums/2nd-...er-ge-fit.html
b - https://www.fitfreak.net/forums/gene...ailer-fit.html
ok, the first one is where _I_ was interested in purchasing a trailer-hitch from someone (who, btw) i never caught up with... lol... whereas the second one is going to be a nice long 10-page read with references and pictures... im fairly sure i read that thread, and maybe some of its links, in its entirety - because it was interesting... the posts are from 2012, so the fit is either 1st gen or 2nd gen (i dont remember, atm) - but what i DO remember is that he (and prolly a different thread, it was a SHE) were able to tow successfully...
hopefully that will get you started, in particular, start with that last-link which i will repeat again...
and, from memory, the one item i was remembering is useful-to-add is a supplementary cooler to the engine-compartment/radiator... forgotten the details, but im sure that they are here somewhere - because i dont have a good-enough imagination to make that up...
hopefully, these help get you started... sincerely (no snippiness involved), h.
Old Mar 22, 2018 | 08:57 AM
Bassguitarist1985's Avatar
Dont forget my threads! I have plenty of pictures too.
Link for Trailer wiring - https://www.fitfreak.net/forums/3rd-...ml#post1280639
Link #2 - https://www.fitfreak.net/forums/3rd-...ml#post1281402
Link #3 - https://www.fitfreak.net/forums/3rd-...ml#post1282400
Hitch installed - https://www.fitfreak.net/forums/3rd-...ml#post1279240
Full Setup - https://www.fitfreak.net/forums/3rd-...ml#post1295846
Class I trailer hitch from Curt Trailers installed
Curt Brake Controller
7 way adapter
This is before I got the air shocks installed. its squatting somewhat, not anymore with the monroe air shocks.
furniture haul 02
tongue toolbox
Mock Setup of Air Shocks
MA811, MA793, and stock shock compare
MA811 installed with 40psi and ~130lb tongue weight on car.
~700 pound lumber run
Tailgating Party with Trailer.
Plate installed. With Monroe air shocks at 50psi, height from ground is 14 inches
The 10" long shank makes it easy to clear the hatch for opening, and helps on the steering angles
Old Mar 22, 2018 | 01:05 PM
GQ_Style's Avatar
That's very helpful both of you.
Sadly I am trying to isolate the results it to the 1st gen GD3 models like the OP has. The new 2018 models seem to be able to tow acceptably.
Old Mar 22, 2018 | 11:06 PM
hfelton's Avatar
sigh - feeling snippy again...
if youd even looked thru the main link id posted - youdve seen
that bassguitarist has some awesome threads with more info than
i think you could handle... but since you seem to be determined
to have answers HANDED to you, rather than doing any research
on your own - then the following link, right there at the TOP says
that they are towing, with a 2009 fit... sigh...
https://www.fitfreak.net/forums/gene...tml#post554818
grrrr... h.
ETA - less snippily, the way that i found/chose that link was by going to the thread-i-linked earlier and then scrolling down a bit where FitStr says they are going to subscribe-for-updates and then links that-thread, claiming that it has some good info... i clicked that link, to see if it mentions the year and the answer was right there at the top...
now, to be fair, maybe you just dont realize that the way to do research is to actually read the articles - or at least skim them - and if your answer is not there, then to click on some likely-looking links - or try to think of some other ways of asking your questions (like using trailer and hitch in a search-term) that might yield more fruitful results... o.O h.
pps - sorry, apparently im still snippy... the last-page of the first-link i gave you had bassguitarist and his awesome threads on it - hence the END of articles and the BEGINNING are kinda where you want to start your research, but dont be afraid to actually scan the first full page of results... sigh...
Old Mar 23, 2018 | 06:21 AM
hfelton's Avatar
apparently, im not completely myself when snippy...
the next link i will provide shows an 07 (yes, the correct series this time... oops) fit which was towing perfectly fine according to all the replies... where did i find THIS link ? when looking back over my own post just now - i looked at the bottom and there were --related-threads-- listed and i realized that the 09 was actually second-gen, like my 13 fit... however, one of those related-threads specifically mentioned the 07 - and assuming that your GD-sport in manual-transmission, then you wont even want/need the transmission-cooler...
https://www.fitfreak.net/forums/gene...need-know.html
now, let me ask YOU a question... are you actually going to DO any towing with your fit ? or were you just curious ? personally, i have not needed to do any towing, but i wanted to have the info in-hand... if you get around to actually doing some towing, would you be so kind as to write-about your experiences ?
Old Mar 23, 2018 | 02:26 PM
GQ_Style's Avatar
No worries hfelton, I have thick skin. Snip away, overall your snippiness/guilt/snippiness/guilt combo provides a wealth of data for me and other members. I simply accept that this is your process and bow to your wisdom.
Thanks for the latest link. I would never try to tow cargo that may weigh more than the GD3 (namely that uhaul trailer filled with bricks). Glad to see some people could.
I want to tow a small tire trailer on my GD3 as 4 track tires/rims won't fit easily into the trunk with my other track stuff. But the 2008 Honda manual warns explicitly against towing. I found a nifty site that has several tow hitches for sale at reasonable prices, but I wanted to see what others did. Also there's the whole matter of the electronics connector box for the hitch. I'm familiar with the transmission cooler trailer hitch combo on the Honda Odyssey, but that van was built to tow some stuff. I'm just glad I didn't see any posts about being thrown off the road while towing something on a gusty freeway. I guess I could always try to put the tires on a roof rack of some sort, that would be interesting as it would make me so top heavy.
Old Mar 24, 2018 | 04:33 AM
hfelton's Avatar
hey-ho, glad to help - and when i was looking over some of your other responses in other threads i realized that you DO know what-the-heck youre doing on cars (more than me, for sure) - and i was being a dolt... whatev - it is all good - and maybe this thread will show-up for others someday, as you said... proving that all-generations of fit have towed safely, whether the manual says you should do so or not...
have fun at the track !! i used to ride and was planning to go to a track-day, but got sidelined many moons ago...
btw - i imagine that there might be some horror-stories from towing available... however from the threads ive read - the worst was just some skittishness on the freeway and the standard braking-distance issues... so, stay safe and dont worry about it since an 07 vehicle is probably out-of-warranty anyways... 8-)
hoopmatch
May 24, 2019 08:23 PM
ncrspike
Apr 29, 2015 04:01 PM
cfesting
Feb 15, 2015 10:12 AM
wmac_
Sep 4, 2014 04:33 PM
discocyborg
Jun 15, 2011 08:22 AM
