Seat Belt icon not light up
hello guys, I see that my Seat Belt icon not light up on dashboard when not use seat belt, anyone know where and what fuse I must change ?
I mean this icon on dashboard:
Honda fit 03
Honda fit 03
So the icon DOES light but not properly. Probably not a fuse.
I'd try to flush the seatbelt buckle receptacle, perhaps something spilled in it in the past. Use rubbing alcohol (isopropyl alcohol) which dries rapidly.
You might still have a bad connection in there. Can the passenger side buckle work on the driver's side?
But when i tilt or shock the plastic (to insert the belt) the icon is light up,
If it were a broken wire I'd expect you could just move the buckle to make the light turn on and off.
If you're good with wires and a voltmeter you can test it.
Soon2015FitWillBeMine
Nov 9, 2015 02:09 PM
