Won't start
Old Dec 20, 2017 | 02:10 PM
Park's Avatar
Won't start
Ive got a 2011 Fit Sport A/T. 13500 miles. It turns over rapidly and won't start. Has half a tank of gas. Newish battery.
When it first happened it started for a moment then died and wouldn't restart. Anyone have any similar issues?
Old Dec 20, 2017 | 03:25 PM
ski's Avatar
ski
A few common causes are bad crankshaft sensor/ignition module/spark plugs, clogged fuel filter, fuel injectors not operating correctly(no signal from PCM), bad fuel pump relay or fuel pump, plugged catalytic converter, bad gas, PCM or electrical system problem.
Is the CEL on?
Old Dec 24, 2017 | 10:29 PM
Park's Avatar
My son cranked it over for 45 seconds and it started. Starts and runs normally now. Put a code reader on it and no trouble codes. Now I'm nervous cause I don't know what the problem was. Maybe a stuck open fuel injector?
Old Dec 25, 2017 | 08:08 AM
ezone's Avatar
Sounds like it was probably just flooded.
What was the last thing done when it ran?
Typical scenario is start the engine, move the car around in the driveway 20 feet to let someone out, shut it off. Next time you try to start it, it floods out and won't start.
Hold the gas pedal to the floor while cranking to help clear the excess fuel. This and other tips are probably mentioned in your owners manual
Try to avoid shutting off the engine until it's been run long enough to get warmed up
Old Dec 25, 2017 | 02:42 PM
ski's Avatar
ski
A no-start problem normally does not resolve itself if a fuel injector is leaking. It's possible water was in the fuel line. You may want to gas up at a different station. Also dump "Dry Gas" in the tank.
Old Dec 25, 2017 | 03:46 PM
ski's Avatar
ski
The fuel pump may also be dying. A previous car of mine sometimes started normally, and sometimes had to be cranked a few times before it started. One day it failed to start at all. The fuel pump died, and had to be replaced.
Phillip S. Chrin
Dec 14, 2019 02:50 PM
Vash
Nov 19, 2018 08:52 PM
Tenuki Kyle Gray
Oct 14, 2014 08:34 PM
IIEZ
18
Apr 16, 2012 07:50 PM
timsfit
Nov 13, 2011 04:55 PM
