Beat Sonic shark fin antenna Duran Duran
Old Aug 21, 2018 | 12:20 AM
marmaladedad's Avatar
It is coming undone!
The 3M adhesive (or whichever brand/no-brand was attached to the base) is no longer....adhesing (hah!).
It has not flown off yet, but the rear of the antenna can be picked up and shifted.
Has anyone else run in to this problem? I followed the typical installation method - clean, alcohol wipe, remove backing on adhesive, then press with a lot of weight (but not too much...flimsy roof), and hold for as long as I can (before my kids come around and bother me).
I am considering epoxy / super glue, but at the same time I may go back to the R/C-car look.
Old Aug 21, 2018 | 08:45 AM
sneefy's Avatar
Don't use epoxy or super glue! If you want to keep using it, go get a roll of 3m automotive grade double sided tape. Clean off the old tape, cut to fit and reapply. Then just keep an eye on it for replacement as necessary. I'd wager it'll be fine though. The automotive grade tape is tenacious stuff. They probably just used crap tape.
Otherwise go back to stock. If you do, I'll take your fin antenna.
Old Aug 21, 2018 | 09:25 AM
Thanks for the advice. I was only half joking about the epoxy; the other part of me was thinking of sheetmetal screws!
I will try to replace the double-sided tape. If that does not work, I will let you know about the fin.
Old Aug 21, 2018 | 09:29 AM
sneefy's Avatar
Silicone caulk? Or just vinyl wrap your roof with the antenna under the vinyl.
Old Aug 21, 2018 | 10:07 AM
sneefy's Avatar
Oh, nice song reference, BTW. Though, 'ordinary world' is my fav on that album.
Old Aug 21, 2018 | 10:58 AM
It goes to show our (or maybe just mine) age.
Old Aug 21, 2018 | 11:04 AM
sneefy's Avatar
Our. That was about my Jr. year in high school.
Old Aug 21, 2018 | 11:17 AM
Pretty much the same (Class of '96).
Old Aug 21, 2018 | 11:27 AM
sneefy's Avatar
Nice. One year after me. Music was so angsty then.
Old Aug 21, 2018 | 01:14 PM
evilchargerfan's Avatar
cant ever keep from falling apart at the seams
cant ever keep from falling apart at the seams ...
mine is not there (yet), but I can def take a finger and poke at the antenna and see it "move" a bit. I'll eventually remove and replace with something with a high weight rating, like:
(rated for 30 lbs, I believe this beats the 3m red stuff)
Gorilla 6055001 Heavy Duty Mounting Tape, Double-Sided, 1" x 60", Black
Amazon Amazon
Old Aug 21, 2018 | 01:36 PM
sneefy's Avatar
Yeah, that'll likely work. Whatever you get, make sure it's rated for weather or outdoor use, else it disintegrate rapidly.
Old Aug 21, 2018 | 05:11 PM
Thanks gents!
SilverEX15
Sep 28, 2014 09:26 PM
alz
Nov 18, 2010 02:12 PM
Chazzlee
Jan 16, 2010 05:48 PM
hdr242
Aug 2, 2008 03:08 PM
R.K.Himura
May 3, 2007 11:20 AM
