2015 - Gear/Transmission Failure?
Old Apr 19, 2025 | 01:57 AM
JTran_SD's Avatar
Car starts up / revs / shifts like normal with no engine light issues but there's no response when pressing on the gas on any gear (reverse through drive/sport/low).
Car wasn't driven for about 3 months and mostly just had to deal with battery issue / recharging the battery, just came back from 3+ hour drive the other day. Is my CVT done for?
Honda fit 2015 Automatic
120k miles
CVT fluid changed last year at 114k miles
Old Apr 19, 2025 | 02:26 AM
2015LXFIT's Avatar
I'd lean more towards electrical related or possible clogged ball circuit/solenoid (if your CVT has hydraulic circuitry - pretty sure they do) considering the seeming sudden onset of the issue. Possibly voltage related also @ TCM. Generally they'll judder before dumping out with the CVTs, you'd know.
Get a proper diag. and look for codes, torque values, line/circuit pressures in TCM. Could be a ground too.
robbbbb
Feb 20, 2024 04:04 PM
Rex Maddox
Jan 20, 2022 03:34 PM
afriedman08
Jun 1, 2017 04:29 PM
PJ Villaflor
19
Jan 20, 2016 02:40 PM
Myxalplyx
Racing
Oct 3, 2014 09:46 PM
