DIY: Acura TL Switchblade Key Fob
Old Mar 28, 2008 | 12:54 PM
Mugen_Dom's Avatar
Originally Posted by its.ryu
Im looking but most of them online are about $50-60. Yours is the cheapest I heard of.
For the TL, there are two different remotes. Memory 1 and Memory 2. Memory 1 was the one I got for CDN$43.07. Memory 2 was quoted at being approx CDN$130-ish. Don't know why there is such a difference, but I went with the cheaper one!!
Old Mar 28, 2008 | 01:01 PM
Rocks A GD3's Avatar
called my local acura they quoted me 75 ish.
Old Apr 1, 2008 | 06:03 PM
Fit of RAGE's Avatar
just recieved my TL key!!
Old Apr 2, 2008 | 04:12 PM
i managed to take everything except for the one little silver screw. Its getting somewhat stripped, gonna have to wait til this weekend to borrow my friends soldering iron to heat it up and attempt to loosen up the locktite. Thanks Mugen_Dom. I'll update this weekend.
Old Apr 2, 2008 | 05:04 PM
methodbasic's Avatar
has anyone tried taking the immobilizer out of the valet key instead of one of the remotes?
Old Apr 2, 2008 | 05:20 PM
JDMchris.com's Avatar
I run THIS
got my key today!
Old Apr 2, 2008 | 05:44 PM
aliencowboy's Avatar
Tagged for interest!
Old Apr 2, 2008 | 10:45 PM
binaryh4x's Avatar
Can somebody post a pic of the underside of the key? Maybe a badge transplant?
Old Apr 2, 2008 | 11:34 PM
kelsodeez's Avatar
UNBANABLE
+1 on that! i asked a bunch of posts back but no one answered me =(
that is the main reason i dont want to do this mod. i dont want my key to say acura when i really drive a honda. i dunno
Old Apr 2, 2008 | 11:35 PM
Mugen_Dom's Avatar
Won't work as the Acura emblem is a different shape to the Honda emblem:
Old Apr 2, 2008 | 11:36 PM
kelsodeez's Avatar
UNBANABLE
do you think a dremel and painting the key would do the trick?
Old Apr 2, 2008 | 11:46 PM
  #32
Mugen_Dom's Avatar
Not sure, but you'd probably need more than paint as the emblem is recessed, so you'd need some sort of filler to go around the 'H' emblem..
Old Apr 3, 2008 | 01:10 AM
  #33
Masterdebater's Avatar
beautiful sir!! excellent and thorough DIY +1
Old Apr 4, 2008 | 03:21 PM
  #34
binaryh4x's Avatar
Found this ebay auction for the key at $47 shipped. The dealers around me are charging $2-$10 to cut...
eBay Motors: 2007 Acura RDX "Switchblade" Main Key OEM (item 310024599464 end time Apr-18-08 15:36:45 PDT)
I was also able to pry the H off my key, so it should go on the new key with no problem.
Old Apr 4, 2008 | 03:34 PM
  #35
Mugen_Dom's Avatar
The RDX key will NOT work with the Fit as the remote transmitter works on a different frequency.
They are selling the TL keys for $58.13
eBay Motors: u 2007-08 Acura TL "Switchblade" Key Remote Mem-1 NEW (item 300213304358 end time May-03-08 16:30:37 PDT)
Old Apr 4, 2008 | 04:55 PM
  #36
binaryh4x's Avatar
Thanks for the quick reply! I got a hold of them and got the ordered changed.... guess that is what I get for ASSuming they were the same...
Old Apr 7, 2008 | 11:23 AM
  #37
So over the weekend i completed the DIY thanks to Mugen_Dom! Just some notes i'd like to add to Mugen_Dom's DIY:
1) When you get down to the three screws that are locktite'd and need to be removed. I was able to remove the two black ones without any trouble, but the silver one seems to be made of a softer material and is more proned to be stripped. So, take extra caution when removing that one. Mugen_Dom mentioned that he heated it up with a soldering iron for 5 minutes and then removed it with a power drill. I ended up cutting the head off the screw and replacing it.
2) In the DIY, when it said to take note of how the spring is positioned on the key. You should take note! I can see how it would be confusing to put back together if you didn't pay attention to how the spring was positioned when you're trying to put it back together.
3) You don't necessarily need the plastic barcode piece that came with your key to get the key cut. You just need your VIN number.
Other than that, everything else went without a hitch. The face on the guy telling me the key isn't going to work before he cut my key was priceless after i started the car with the TL key. Once again thanks to Mugen_Dom for a great DIY!
Old Apr 7, 2008 | 11:37 AM
  #38
Illusive's Avatar
Bahahaha he must have been embarrassed...probably thought you were some guy who thought all Honda/Acura keys are universal and didn't know any better...then PWNED!
Old Apr 7, 2008 | 11:43 AM
  #39
Yeah, it felt great after the car turned. Haha.
Old Apr 7, 2008 | 04:39 PM
  #40
rad_dsm's Avatar
Where did you get the Key fob?
Will you share the name of the dealer where you got the great price on the key fob?
