DIY: Acura TL Switchblade Key Fob
Old Jul 14, 2008 | 11:16 AM
  #81
vinnimac's Avatar
Originally Posted by Fa1
Doesn't the TL key come with an immobilizer chip already? Would it be possible to program that to work instead of taking the chip out of one of your current keys?
Is this true? Can it be re-programmed at home with no expensive equipment?!?!?
Old Jul 14, 2008 | 08:11 PM
  #82
loud_tiger's Avatar
no.
here's mine:
Old Jul 15, 2008 | 02:20 AM
  #83
Gigarange's Avatar
Well, I got the $30 key from the guy on Amazon.com, and it's perfect! An Acura TL, OEM key. Now if I can just get it apart......
I should have openned my brain a little and did some thinking, and could have saved myself some money by going to an Acura dealer locally and bought it there! duh Just got so excited that I found it. and then I realized we have it in the first post of this thread. (part number, that is) Oh well, maybe I'll start paynig attention to things now.
I can't find anything except the $74 one!
is there a way to search for a certain user on there? Did the guy you got yours from have more then one?
Old Jul 15, 2008 | 11:28 AM
  #84
vinnimac's Avatar
That could be the case because I just went back looking for him after I saw your post, and can't find him (her?). Might have been he only had one to get rid of. Sorry for psyching anybody out, didn't mean to.
I you take the key to the dealer, can they reprogram the immobilizer chip, or do you just HAVE TO take one out of a Fit key??
Old Jul 15, 2008 | 01:41 PM
  #85
Mugen_Dom's Avatar
You cannot reprogram the immbolizer from the TL fob to work with the Fit.
There is a letter stamped onto the blade of the TL and Fit keys. If they were the same, then you would be able to reprogram it but they are not the same. (The TL is a 'V' but can't remember what the Fit is).
You HAVE to replace the immobilizer chip or you will not be able to start your car!!!
Old Jul 15, 2008 | 06:19 PM
  #86
Fa1's Avatar
Fa1
I have a 'V' on my fit key...
Also for anyone wondering, memory 1 and 2 are the same and the feature is only used on the TL to recognize if it's driver 1 or driver 2. Disabling the memory feature when you program the remote makes both memory 1 and 2 the same.
Old Jul 15, 2008 | 08:09 PM
  #87
vinnimac's Avatar
I am not trying to call you out, but my Fit key HAS a 'V' on it, too so shouldn't they work with each others car? Again, no insult intended, but where is that info coming from? just want to make this work without giving up a key, if I can!!
Old Jul 15, 2008 | 08:48 PM
  #88
Mugen_Dom's Avatar
All of my Fit keys have an 'H' on it.
My Fit is an 07, so maybe they changed the immobilizer on the 08's??
I dunno. If that's the case, then you shouldn't have to replace the immobilizer, just get Honda to reprogram the immobilizer. No guarantees here, as if it doesn't work, Honda may still charge you!! Depends on how 'close' you are with your dealer.
I say give it a go and try it out!
Old Jul 16, 2008 | 01:50 AM
  #89
Gigarange's Avatar
mine is an O8 and has a "V" on the key as well, might give it a try, just have to find a not SUPER expensive key first.
Old Jul 16, 2008 | 02:05 PM
  #90
dyussen's Avatar
Anyone with the 08 Fit Sport get this to work ? As someone noticed, the 2nd part of the FCC ID doesn't match that TL key. Just checking before I might buy the FOB and give it a go.
Old Jul 16, 2008 | 07:16 PM
  #91
Gigarange's Avatar
dyussen, check on page 4, you'll probably find the answer.
Old Jul 18, 2008 | 11:14 PM
  #92
michaelpotter's Avatar
Originally Posted by dlong
The FCC ID on my remote is NHVWB1U523 ('08 Base Fit w/ Remote Entry Added).
-d
I bought a switchblade key off eBay using FCC ID:NHVWB1U521. I found out it's compatable with FCC ID:NHVWB1U523. Programmed it today and it works great.
Now to get the transponder out of my base Fit key or buy one to insert into the switchblade. Can anyone confirm that the transponder chip type is RW.:MAGAMOS 48 ID : MG10? That's what it looks like on this site that sells the chips Transponderkeys ,Transponder key blank ,keys , TOYOTA HONDA AUDI,VW,
Old Jul 19, 2008 | 12:25 PM
  #93
dyussen's Avatar
Originally Posted by Rocks A GD3
So over the weekend i completed the DIY thanks to Mugen_Dom! Just some notes i'd like to add to Mugen_Dom's DIY:
1) When you get down to the three screws that are locktite'd and need to be removed. I was able to remove the two black ones without any trouble, but the silver one seems to be made of a softer material and is more proned to be stripped. So, take extra caution when removing that one. Mugen_Dom mentioned that he heated it up with a soldering iron for 5 minutes and then removed it with a power drill. I ended up cutting the head off the screw and replacing it.
2) In the DIY, when it said to take note of how the spring is positioned on the key. You should take note! I can see how it would be confusing to put back together if you didn't pay attention to how the spring was positioned when you're trying to put it back together.
3) You don't necessarily need the plastic barcode piece that came with your key to get the key cut. You just need your VIN number.
Other than that, everything else went without a hitch. The face on the guy telling me the key isn't going to work before he cut my key was priceless after i started the car with the TL key. Once again thanks to Mugen_Dom for a great DIY!
Just another couple pieces of feedback for anyone else planning this DIY. I had the opposite happen as RocksA. The small silver screw came right out and the other two wouldn't budge and started to strip. After a trip to the local hardware store to get the best screwdriver, ended up working with a #1x1-1/2" phillips. I bought some new miniature machine screws with the same threading to replace the partially stripped ones for 25 cents each.
Honda cut the key for me for free so that was a deal and off I went - worked perfectly.
One thing threw me. The immobilizer chip in my 08 Fit Sport key did not match the glass tube style. In fact it was identical to the one I took out of the TL fob. This lends to the theory that if your key says "V" (mine did) you don't need to hassle with this and can get it reprogrammed. It is a flat black plastic piece, rectangular from the side and quite small. Looking at it from the side it's not quite a perfect rectangle - one end is a hair longer. The bad news is it was rather tough to get out. I had to tear away most of the plastic around it with a small needle nose pliers until I could wedge one end underneath it and break the glue. The good news is I didn't have to mess at all with drilling the chip space in the FOB because it went in perfectly.
The drill tip worked perfectly for popping out the TL chip. I used a very small 5/64 to make a hole in the surface and when I felt it break through I pulled it back out and then by hand pushed a smaller 1/16 bit though the hole and popped it out.
Good luck all!
Old Jul 29, 2008 | 02:52 AM
  #94
Blaw's Avatar
Very interesting! I cannot find a switchblade key with FCC ID:NHVWB1U521. I am guessing you have a Base Fit with keyless? This means that base owners may do this mod. I want to do this mod because having the key separate from the keyless remote is kinda annoying.
Old Jul 30, 2008 | 08:10 PM
  #95
It's a Fit LX (Canadian version), keyless is an OEM option I purchased from Bernardi Honda...
Old Jul 31, 2008 | 01:33 AM
  #96
Blaw's Avatar
Ah, didnt realize you are from Canada.
Do you have a part number for the switchblade key that you got off ebay?
Or a link?
Thanks in advance.
Old Sep 21, 2008 | 02:37 AM
  #97
aenokea's Avatar
Sorry to resurrect an old thread, but does anybody know if this will work on the 09 keyfob?
Old Oct 24, 2008 | 03:09 PM
  #98
FitStir's Avatar
Question Good question
Has anyone tried this with the 2009 GE8 yet?
Any chance up re-upping the DIY pics? That would be greatly appreciated.
Old Oct 25, 2008 | 04:35 AM
  #99
Fa1's Avatar
Fa1
What is your FCC ID?
Old Oct 25, 2008 | 11:16 AM
  #100
niko3257's Avatar
FitFreak GE8 DIY Guy
on my sport key fob
FCC ID: MLBHLIK-1T
IC: 2500A-HLIK1T
MODEL NO. HLIK-1T
