DIY: Dust/Pollen Filter Replacement
Old Jul 7, 2010 | 05:59 PM
  #61
Carbuff2's Avatar
Originally Posted by beatricethecat
mine hasn't gone on yet, but when i went in for an oil change they told me next time i should get both air filters replaced
If the shop reset the MM at the oil change, THEY ALSO RESET THE FILTERS' REPLACEMENT NOTICE. So if, say, the sub-code for engine and cabin filters on the MM came on at an oil change around the 30,000 mile mark, and the MM was reset, the sub-code for the engine and cabin filters would not display again for 30,000 more miles.
You can see what sub-codes will display on the next oil change warning by cycling the trip odo to the MM oil life %. Then push and hold the button again and the upcoming sub-codes will display.
Old Aug 7, 2010 | 11:10 PM
  #62
ElanS2's Avatar
Add a cabin filter to your Fit without AC
Hello All,
My 2007 DX manual doesn't have AC and therefore did not come equipped with a cabin filter.
I got curious and pulled the tray where it would have been and realized that all I had to do was cut some plastic fingers and my tray would be ready for a filter. The tray is the same with or without the filter. When there is no filter the air passage is blocked by a plastic baffle held in place by several plastic fingers. The baffle simulates the air flow resistance of a filter. Cut the fingers, remove the baffle, and add the filter and you have just upgraded your car.
Cheers
Rod
Old Sep 5, 2010 | 10:42 AM
  #63
TheYellowLobster's Avatar
Can't believe the dealer wants over 70 bucks to do this!
Old Sep 5, 2010 | 10:03 PM
  #64
ElanS2's Avatar
And you can buy the filter on-line for a pittance. Get several at once and you may get free shipping too!
Honda won't like me but a guy deserves a deal once in a while ... no?
Cheers
The cheap Canadian
Rod
Old Sep 24, 2010 | 01:44 PM
  #65
eskateboarding7's Avatar
Simple DIY, but commonly overlooked. Those things get pretty nasty after a while.
Old Sep 25, 2010 | 03:11 PM
  #66
pattyd's Avatar
cabin air filter
Wow, thanks so much. Your pictures really did the trick. I even found stuff that fell behind the glove box. After 70k miles my filter was pretty dirty. I used my compressor to blow out the obvious debris and will have to break down and buy a new filter, but I'd rather do that than pay the dealer $75+ to replace it. I LOVE THIS FORUM!
Old Sep 29, 2010 | 12:14 AM
  #67
Sylak's Avatar
I love you guys lol, I had to go to the dealer today for my oil change ( i run syntec oil) i make them did the oil change only already 90$ Can. a filter is 20 and the cabin filter 39$. the service guy ( my dealer got good service really nice people, but still overprice) told me my filters should be change they ask 112$ ( plus taxe) so it is like 50$ in time... damn the air filter took me 30sec to change ( super easy compare to my old E30). but i was fearing that the cabin filter would be complicated... it seem that i was wrong! more like 2-5 min...
i need yo find a cheap filter now ( 39$ is too much for a filter!) :-)
Thank Man for that i was searching for that kind of DIY
Old Nov 22, 2010 | 12:11 AM
  #68
StormSilverGD3's Avatar
I must say, I am so glad that this has been helpful to the Fit community over the past 2 years. makes me feel good! I wish I still had my Fit...I miss it.
Old Dec 27, 2010 | 04:37 PM
  #69
Zzyzx's Avatar
Many thanks "SSGD3". You saved me about $80 by posting this DIY.
Old Dec 28, 2010 | 12:46 PM
  #70
glad to hear it zzyzx!
Old Apr 28, 2012 | 01:33 PM
  #71
raiderfit's Avatar
thank you for this thread. i just found it and it's very helpful. Thanks!
Old Apr 28, 2012 | 08:19 PM
  #72
ElanS2's Avatar
Really cheap filters like cents
Hello all fello cheapos.
If you want a really cheap filter just get a furnace filter and cut it to size.
Even the smallest filter will make several filters for your fit.
You can get the furnace filter material in a folded up sheet and make more filters than you will ever need.
Easy to find at any Canadian Tire store and often on sale.
I do the same thing for my Subaru Legacy Turbo.
Cheers
Rod
Old Oct 16, 2012 | 12:17 PM
  #73
I had moved all of my stored photos so I updated the URLs on this DIY. All the images are back now!
Old Oct 16, 2012 | 12:21 PM
  #74
batman697's Avatar
That's great. You've saved myself and probably countless others tons of money. Dealers really rip people off for this install.
Rellikant
Aug 29, 2017 12:38 PM
2Rismo2
Jun 20, 2017 07:57 PM
andeano
Mar 14, 2015 07:50 PM
BlueBlazer49
Apr 26, 2011 07:46 PM
Fitcious
Jan 20, 2011 08:57 PM
