After 100,000 miles...
Old Dec 11, 2008 | 04:26 PM
Oofie's Avatar
What should I do, maintenance wise? I've been doing:
regular oil changes
ATF changes every 30,000 miles
air filter cleaning
tire rotation
brake pad changes
Should I do something special (maintenance wise) since my Fit is at 101,000 miles now? Should I do a coolant flush? Brake fluid change? Any recommendations? I'm planning on doing my ATF change this weekend and I was wondering what else should I do since I'll be under the car already.
Old Dec 11, 2008 | 09:22 PM
DOHCtor's Avatar
-Coolant flush...
-Spark plugs...
-Injectors cleaner...
Routine maintenance....
Marko!!
Old Dec 11, 2008 | 10:21 PM
Im|Inside|Fit's Avatar
LOL! after all this time i think you should already know what to do =P lol but hmm i guess you can jsut do everything and make sure everything is good to go =) and man thats alot of freaken miles what do you do for a living? =P wait! is this for your fit or your other car =P
Old Dec 12, 2008 | 07:47 AM
Oofie's Avatar
Thanks Dohctor, forgot about the spark plugs.
Dennis, yeah, I do a lot of miles as a courier. I bought my Fit with the sole intention of using it as my work car. I bought it January of 07 and as of now, I have 101,300 miles on it and still going strong. No problems whatsoever (knock on wood) except for the time my Fumoto valve opened while I was on the freeway. I ran the fit for about 5 minutes before noticing I was losing oil. The bimmer in my sig was sold a few months back when it hit 50k miles.
As for the coolant flush, do I just use the drain plug under the radiator? Will that also drain the coolant in the engine?
Old Dec 12, 2008 | 09:01 PM
DOHCtor's Avatar
I cannot tell you about the coolant... at my job, i remove the plug at the rad, then i start the car and i plug a garden hose at the inlet and then i let it run 'till the water comes out clear!! :P
On my Mazda V6, you flush the rad and remove the water hose from the oil cooler and you're ok!!
Marko!!
StinklePink
Sep 25, 2018 05:55 PM
sarasube
Jul 4, 2018 11:08 PM
madtodaimax
Sep 4, 2012 11:01 PM
JDMxGE8
13
Mar 20, 2012 02:04 AM
I like being Fit
Feb 23, 2010 12:22 PM
