Changing MT Fluid: An Observation
Old May 27, 2010 | 02:00 PM
Marrk's Avatar
1.6 U.S. qts. is what my Fit '07-'08 Service Manual says (Page 13-3).
I am speaking of the manual transmission.
Old May 27, 2010 | 02:10 PM
mdbrich's Avatar
I changed my ATF yesterday actually. The fit hit 30068. So I performed all the 30k stuff. I can feel the more smooth shifting after the change was made. I am wondering if this will effect MPG. I am going to keep on the lookout.
Old May 27, 2010 | 05:06 PM
apexanimal's Avatar
excellent. thank you.
Old May 27, 2010 | 05:22 PM
dr_time's Avatar
MTF change
Is this difficult to do? Is it just a drain plug somehwere?
Old May 27, 2010 | 05:28 PM
Marrk's Avatar
The only reason I dislike changing MTF or diff fluid is that you have to fill "to overflowing." That's how you know you have enough fluid in the case. It's a dumb design, but it's been this way on all cars since forever.
The fill hole on the Fit MTF is a little awkward to reach, but no biggie. You will need a small plastic pump. Buy them at an auto parts store. They fit right into the MTF bottle. Use once and throw away (if you like).
Always loosen the drain hole first.
And use new washers when you button everything up.
Old May 28, 2010 | 10:15 AM
S4guy2000's Avatar
CR! Dang . . .
Bought it new? How many miles were on that CR when you bought it?
(I have CR envy. It's an unattractive personality flaw, I know. I'm trying to get over it.)
Not to thread jack, but I bought the CR used this past March. It is an 08 and I got it from a nice bloke in Louisville, KY with just under 3800 miles on it. It now has 4200 miles on it and it runs like a sewing machine.
The CR is the best car I have owned and I have owned a lot of nice machines (M3, S4, Integra GSR, CRX Si, Civic Si, 420 Sel, etc.).
Old May 28, 2010 | 11:29 PM
polaski's Avatar
Yeah what a pain. Thats why drivers of older Hondas cheated with the VSS sensor - fill with funnel/tube until it comes out the actual fill plug (or if you were lucky and had a 1.9qt tranny just put in the whole 2 and not even bother with the fill plug). I'm still trying to figure out the best way to do this with the fit as the VSS is in a really crappy spot.
Always loosen the fill hole first.
Fixed. Don't take it apart if you can't put more in! Thats a real pain when that upper plug is seized beyond the capacity of your wrenching arm!
Old May 28, 2010 | 11:39 PM
Marrk's Avatar
Sorry polaski. My bad. You are correct, sir. That is what I meant to say.
cakacon
Jul 26, 2023 05:30 PM
benareeno
Oct 25, 2022 01:39 PM
JerryHughes
Mar 25, 2021 08:42 PM
regular.dude
Oct 6, 2014 03:59 PM
Mister Coffee
Sep 12, 2014 03:34 PM
