DIY: Fog Light Lens Fix/Replacement
Old Jul 5, 2012 | 09:20 PM
running's Avatar
D50,
I'll let you know, I just did the repair on mine using polycarbonite, the same as lexan I thnk. I did make a mess out of the sealant though, next time I'm going to clamp the lexan to the housing then apply the sealant. I will install it tomorrow. I just ordered the Head light armor GT yellow film to protect the other side, I'll give you a heads up on that too although I've heard nothing but good things about their product.
Ed
Old Jul 5, 2012 | 10:24 PM
heymikesays's Avatar
Originally Posted by D50boy
Has anyone had issues with the Lexan melting? I have a broken fog and I'd like to get going on a repair for it. I don't want to have to re-do it after melting though.
just confirming that they do melt. i've had my replacement on for over a good year now and its intact, yet you can still see soft points that have melted over time (stopped using the fog lights since)
still exploring glass replacement. will post if I find any updates.
Old Jul 5, 2012 | 10:37 PM
running's Avatar
Mikey,
Thanks, if you could post your findings me that would be outstanding.
Old Jul 8, 2012 | 04:51 PM
running's Avatar
I tried this procedure and I didn't use enough clamps, needless to say it turned out like a train wreck. I used sealant opposed to epoxy. I also used 1/8 thick polycarbonite. Other than the clamps any other thoughts? Thanks.
Ed
Old Aug 19, 2012 | 03:06 PM
JH-FITS5M07's Avatar
In another post, I read we should use LED bulbs to avoid the heat on the lexan...
Old Aug 19, 2012 | 08:57 PM
Ed
the problem with the clamps is that you need several of them to hold all the pressure points down until the sealant takes effect. besides that, the only alternatives I can see are some heavy duty tape to suspend it (at the risk of some major sticky residue after pulling it off)
Old Aug 29, 2012 | 08:48 PM
Just about to sell the 2007 Fit Sport, had to fix the fog light.... Follow the steps found here. These are the stuff I used...
Aznsupastar
Sep 6, 2018 10:12 PM
cwinfrey
Mar 8, 2014 08:44 PM
.eL
Aug 20, 2012 06:22 PM
running
Aug 7, 2012 03:52 PM
OrangeRevolution
May 15, 2010 12:51 AM
