dysfunctional radiator fan or temp sensor? 2007 Fit
Old Nov 7, 2013 | 02:30 PM
wzard999's Avatar
Okay, folks, got under this morning. Everything checks out. I discovered that I can check the operation of the ECT sensors by measuring their resistance. All I had to do was pull the plug on the ends of them to gain access to their electrical prongs - then, apply a multimeter. The one at the thermostat was a pain in the rear. Couldn't see it, so I had to feel my way around with a couple multimeter prongs. You can probably imagine what that was like. Here's the results:
At approximately 45 - 50-degrees Fahrenheit outside air temperature:
Cold Engine
at thermostat = 3.85 k ohms
at radiator = 4.43 k ohms
At approximately 50 - 55-degrees Fahrenheit outside air temperature:
After idling for 20 minutes with heater on
at thermostat = .40 k ohms (and no fan action)
at radiator = 3.65 k ohms
Fuse and relay also checked out. No MIL. I'm not sure what the temperature equivalent for .40 k ohms is, but it's got to be pretty high. I'd still be enlightened to know (Maybe I should ask for a scanner for Christmas ). At any rate, as evidenced, the sensors are working properly. I appreciate everyone's input on this. Clearly, I was freaking over nothing. GAWD, how I just LOVE acquiring new (used) vehicles and pouring over all of their idiosyncrasies
Old Nov 7, 2013 | 03:26 PM
Texas Coyote's Avatar
I know what you mean about idiosyncrasies, one of my other cars is an Eldorado with a Northstar engine and drivetrain. It's like a beautiful woman that you have an unbelievable sex with but is otherwise a total bitch.
Old Nov 17, 2013 | 08:58 PM
wzard999's Avatar
fans kicked on today
UPDATE:
Got under the car today - an unseasonably warm day (mid-70s) - to do some investigating with a stethoscope (see other topic here: https://www.fitfreak.net/forums/gene...oid-valve.html). After about a half hour (guesstimating) of idling, the fans kicked on. . . . for a total of 3 seconds. Another 10 to 15 minutes of idling, and the fans kicked on again for another 3 seconds. This puppy likes to run HOT! How hot? I'm still not sure, but it's definitely hotter than most.
Now, if only I could subdue my worries about that incessant tapping that i've been documenting. Feel free to venture into the link above. The way I see it, the more insight I can get from you folks, the better. As a new owner of an old car with lots of marathons under its belt, these 'things' concern me.
@Texas Coyote: Personally, I'd like to hook up with the tramp from Sant'Agata who goes by the name, Reventon. Hey, no harm in dreaming, right?
gerard6496
Jan 12, 2024 02:12 AM
Walt911
Aug 26, 2018 03:35 PM
cakacon
Mar 2, 2018 12:02 PM
fit4jdm
Oct 21, 2008 01:39 AM
Edward Man
Oct 16, 2006 10:53 PM
