805FitSport redone nitrous set-up... pics inside (IAT sensor relocated!)
Old Mar 20, 2007 | 04:38 PM
  #41
07TaffetaFit's Avatar
Originally Posted by 805FitSport
so i think i got a better mix now, 20 fuel and a 38 nitrous... still keeping it a little rich i think, but its a 70 shot, and heres the video, cold bottle, but 75% full bottle about 900 psi. notice my 30 mph- 40 mph jump lol.
sorry for the crappy camera phone vid again, at least this time it has some sound... taken with me new verizon LG envy...
How do you tell if you are running to rich or lean, and know which jets to change?
Old Mar 20, 2007 | 05:01 PM
  #42
805FitSport's Avatar
these jets on a return fuel system car would be just right, but since these cars run a returnless system, they have a high pressure line of fuel, there for you will need to back off the fuel more. i need to check what the fuel pressure is before i start backing off the fuel.... your ZEX kit should do it automatically for you though.
Old Mar 20, 2007 | 05:47 PM
  #43
ahhh okay gotcha...you have a different kind of system...thanks again
Old Mar 20, 2007 | 10:21 PM
  #44
By the way, how hard was it to tap into the fuel system on the Fit? I scheduled to have it installed, and the people seemed to be worried about how to tap the fuel...
Old Mar 21, 2007 | 01:13 PM
  #45
if you look at my 1st post about nitrous i explain the whole fuel tap thing.... 1st off do not cut the fuel hose its lined with plastic. remove it being carefull with the plastic clips and then by some high pressure fuel hose from your local auto parts store along with a small brass T as shown in this pic:
do not try using the zex T cause its a little on the big side. buy some good fuel clamps that are not going to puncture or rip into the fuel hose. i got mine from some subaru fuel rails that i have laying around. then you should be set!
Old Mar 23, 2007 | 12:05 PM
  #46
Okay, so I went to have it dynoed today to make sure the a/f is good, and on the baseline dyno around 5200rpm the car starts going really lean...the guys like, "Thats not even on nitrous, so I am gonna try it one time on the spray and if it does the same thing Im done." By the way I made 103whp and 99.9TQ on my baseline. Anyway so he sprays the nitrous and of course at around 5200rpm the a/f immediately starts to jump so he lets off. I dynoed 141.2whp and 147.7TQ on that run and then he said they were done.
SO my question is, do I need to get a better fuel pump? What could be my problem?
Old Mar 23, 2007 | 01:03 PM
  #47
thats weird, i say put a bigger fuel jet in the fuel line, the Fit puts out a good 51 psi of fuel pressure so a bigger pump is not needed. what jets are you running? your header might make you go a little lean.
Old Mar 23, 2007 | 04:21 PM
  #48
thats what I said, but the car ran real lean above 5200rpm without nitrous...so something isnt right, and it has nothing to do with NOS jets
Old Mar 23, 2007 | 05:04 PM
  #49
its your header man, that thing is messing with the AFR's what was the EGT like?
my car runs rich! even with the nirtous.
Old Mar 23, 2007 | 06:49 PM
  #50
I dunno, doesnt say on the graph, is there anything I can do? I guess I could get an AFC2 to adjust the fuel at different rpms...
Old Mar 23, 2007 | 07:31 PM
  #51
yea i think your going way lean because of all that exhaust flow, you got header, test pipe and the big skunk2 exhaust
try doing the coolant bypass mod, it will make the car run slightly more rich.
Old Oct 27, 2014 | 03:02 AM
  #52
Myxalplyx's Avatar
THIS thread is a pleasant surprise. Was searching through and found it. Very interesting! Nothing to add. I just needed to tag it for future reference.
Captain Bemo
Oct 22, 2016 09:05 PM
Orcshine101
Oct 5, 2015 11:25 PM
Flawededge
May 6, 2015 01:13 AM
brs5tettba
Dec 9, 2013 06:10 PM
