What gauges do I need to go with a Turbo?
Old Feb 15, 2008 | 08:53 PM
BlueCell's Avatar
Originally Posted by fshwcrs
If you get them will you know what you're looking at and what it means?
If not, then just get the gauge pod that looks the best to you and fill it with whatever gauges light up in the color you want.
I wasn't just going for looks on gauges. I needed to know what kind to get and what it does with why I need it. Yes this is my first Turbo, but its also good to get as much info as I need to help maintain it so I don't mess up my engine. I'm going with Boost Gauge, Oil Pressure gauge, Water Temp gauge and a Wideband from AEM. That will be my gauge set-up
Old Feb 15, 2008 | 09:23 PM
kennef's Avatar
look into the apexi tru boost. it is a boost gauge and electronic boost controller in one and i would recommend you column mount it so it is readily in your line of sight as you check engine rpm. good electronic boost controllers do a better job of keeping consistent boost pressures as ambient air temp changes.
as for the others, i would recommend you mount those somewhere low and out of the way. those gauges aren't the sorts of things that you need to scan continuously. and avoid pillar mounting of gauges if you want to keep the riffraff away.
Old Mar 16, 2008 | 08:02 PM
gmane's Avatar
Originally Posted by jdjohnson9
A boost gauge would be pretty helpful. Otherwise it all depends on what gauge pod your gonna get. There are a whole bunch of gauges you could get. Air/fuel ratio (not really needed but cool) Oil temp, Water temp, Oil pressure, Voltage, Exhaust pressure........ I would stick with boost, water temp, and oil pressure but thats my opinion. Its all up to what you want to keep tabs on. How are you gonna mount the gauges and how many are you gonna get?
I would actually recommend the A/F gauge so you know how lean/rich you are running seems pretty essentail to me. I had a 98 LS Intergra with a Drag 3 turbo kit and the only 2 gauges I had were boost and a/f and i had a apexi boost controller. I would also recommend an oil temp gauge.
Old Mar 19, 2008 | 11:28 AM
Kostas's Avatar
You are need a EGT (Exhaust Gauge Thermometer) because if for some reason the fuel ratio be poor, the exhaust temp goes on.
This is mine that say 233 C.
Old Mar 19, 2008 | 12:53 PM
Illusive's Avatar
Moved to appropriate forum.
Previc93
Jun 25, 2010 09:29 AM
azkikersfit
Jul 27, 2009 08:16 PM
YeeFit
Jan 14, 2009 04:16 PM
xorbe
May 31, 2008 02:54 AM
FitSport2007_5spd
44
Apr 8, 2008 09:41 AM
