Review: Weapon R Intake Manifold
Old Nov 13, 2014 | 11:59 PM
Rollerboots666's Avatar
^^^ Hahaha 6.5 year update
Old Nov 14, 2014 | 05:52 AM
kylerwho's Avatar
spoon fed
sugarphreak hasn't logged on since December 2013 and he sold his fit as far as I know.
perhaps look here:
https://www.fitfreak.net/forums/fit-...g-results.html
Old Nov 14, 2014 | 12:01 PM
perhaps look here:
WOW there were some major issues going on there. I really wanted to see what the WR manifold does for numbers but ultimately I wonder how it affects low end power and response.
Old Nov 14, 2014 | 08:54 PM
kylerwho's Avatar
spoon fed
When I had it, it felt like the low end suffered more but the top end did pull better. However I don't have any numbers to back that up.
Honestly I have been looking into swapping a ge8 plenum onto a gd3 aluminum intake runner to see if that helps improve the powerband.
Old Nov 15, 2014 | 12:35 AM
Swapping the plenum? Does that work? So does the plastic GE plenum flow better or something?
Old Nov 15, 2014 | 09:17 PM
kylerwho's Avatar
spoon fed
according to the crz guys it does. Spoon also uses it as their upgraded manifold for the crz. I gotta dig around to find some numbers I saw at one point. It appears it adds 6wtq and 4-5whp throughout the power band.
the ge8 has a dual plenum design vs the gd3 is just a straight plenum.
Old Nov 16, 2014 | 11:37 AM
So you use the stock GD runners and the GE plastic plenum? The throttle body position (intake position) and everything is the same?
Old Nov 16, 2014 | 08:51 PM
TPColgett's Avatar
Hmm... I have a Weapon R mani... The SHG_Mike plenum style mani and it wouldn't be hard to get a GE upper plenum for testing purposes.... Now all i need is a friendly dyno LOL
Old Nov 16, 2014 | 10:27 PM
Damn i'd like to know about the GE upper plenum.
TPColgett are you currently running the WR mani?
Old Nov 19, 2014 | 08:15 PM
kylerwho's Avatar
spoon fed
the throttle body intake flange is different along with the gasket. Im not certain if a gd3 throttle body will work with a ge8 manifold. Perhaps someone could use a ge8 manifold and throttle body.
More lower end torque is what would be affected the most.
BUCHOG92
Feb 6, 2021 12:58 PM
Bongobennie
17
Nov 4, 2018 06:00 PM
valhalla
Jul 15, 2012 10:13 PM
alf74
Jul 24, 2008 01:30 PM
tonyrace_41
Jun 21, 2006 09:55 AM
