64mm Throttle Body
Old Aug 29, 2008 | 05:25 PM
  #121
kylerwho's Avatar
spoon fed
Originally Posted by Sugarphreak
2006+ S2000's should have a DWB 64mm version. The pics I have seen of them look promising. Sounds like lots of owners don't like the DBW setup and swap them out for a cable version RSX-S throttle body, maybe that means there are some good deals to be had?
How sweet would that be if it uses the same voltage, bolt pattern and plugs.
that would be legitimate. time to research.
Old Aug 29, 2008 | 05:37 PM
  #122
kylerwho's Avatar
spoon fed
S2000 throttle body assembly
honda fit's throttle body
Old Aug 29, 2008 | 06:11 PM
  #123
Sugarphreak's Avatar
Push My Button
definitely has a larger bolt dia if that is 64mm, plugs look compatible though. You could always fab up a mounting backet and mount the unit at 45 degrees.
Old Aug 29, 2008 | 06:14 PM
  #124
kylerwho's Avatar
spoon fed
there is room for that under the fit hood. i think it is a 66mm tb. looks like cooling nipples and dbw plug are similar but do they send the same signals?
Old Aug 29, 2008 | 06:20 PM
  #125
Push My Button
No idea about signal/voltage required, but they are both Honda so hopefully they share some common traits.
Old Aug 29, 2008 | 06:22 PM
  #126
kylerwho's Avatar
spoon fed
wonder where we could find the info on signal and voltage output?
Old Aug 29, 2008 | 06:40 PM
  #127
Tofuman's Avatar
^ first thing that came to mind was Blitz or Pivot. they make throttle controllers, they might be able to let us know that info. just a guess.
Old Aug 30, 2008 | 02:09 AM
  #128
alf74's Avatar
I'm happy to see that you're thinking about TB and its importance.
This document will help you to understand more...
http://www.vems.hu/files/MembersPage...n/gaspjeld.pdf
I'm sure that at the end someone will change its stock TB!!!
Old Aug 30, 2008 | 04:43 PM
  #129
kylerwho's Avatar
spoon fed
so the edm tb is a drive by wire system?
Old Aug 31, 2008 | 01:43 AM
  #130
Push My Button
So I wasn't able to bolt in the Rev2 manifold today. However I got 2 dimensions to report;
Air intake side of the TB measured out to 64mm, it clearly gets smaller inside of course.
The WR manifold measured out to 55mm,
Will get the outlet side of the TB measured up once I have it apart either tomorrow or on Tuesday.
So somebody was saying the new 09's have a 52mm TB? Sounds promising!
Old Aug 31, 2008 | 06:29 AM
  #131
alf74's Avatar
55mm and 64mm!
Seems that your Tb doesn't need to be upgraded...
That's another reason because vtec is more powerful than idsi....
The new 09's should have a smaller TB? 52mm vs what?
Old Aug 31, 2008 | 02:05 PM
  #132
bluerice's Avatar
tagging for interest
Old Aug 31, 2008 | 03:55 PM
  #133
kimo's Avatar
Check this:
Maxbore.com throttle body boring service
They do TB porting.
Karim
Old Aug 31, 2008 | 04:20 PM
  #134
bbpGEftmfw's Avatar
tb boring is good if you want to still pass emissions and what not, but the gains are very minimal. I would gladly swap my tb's every 2 years if I could have a 60 mm tb that would have a 53mm manifold opening and actually make about 3 hp for 300 dollars instead of 1/2 hp for the 150 it would cost to rebore the stock one.
Old Aug 31, 2008 | 06:39 PM
  #135
Push My Button
Confirmed today that the inside dia of the TB on the manifold side is also 55mm. So the only restriction is the actual butterfly dia itself which I assume is 45mm.
Would be interesting if the new Fit has a butterfly of 52mm and the same inlet and outlet dia. Would be a direct bolt in then
Old Sep 1, 2008 | 02:16 AM
  #136
bbpGEftmfw's Avatar
I'm pretty sure that all throttle bodies taper down so I would be suprised if the inner diameter is no bigger than 46 maybe 47 mm on the inside.
Old Sep 1, 2008 | 02:35 AM
  #137
alf74's Avatar
Then you need upgrade....
Old Sep 2, 2008 | 07:44 PM
  #138
Masterdebater's Avatar
next 09 fit that comes in to get pdi'd ill see if i can measure the throttle body on it.
Old Sep 13, 2008 | 02:48 PM
  #139
diedwater's Avatar
so why won't the JDM DBW ones work? I know at least J's makes a DBW model, donno about spoons tho...
Old Sep 24, 2008 | 10:01 PM
  #140
DOHCtor's Avatar
A 64 mm Throttle body would definitely be too big for a 1.5l engine... I used to mod many Neons in the past and i can say for sure than swapping a 49mm Mtx Tb for an 52mm ATX Tb on a neon gives more or less 6 to 10Whp depending on mods...
found this on the web a long time ago... sorry, it's from a neon forum but it should apply on all engines!!
Gary Howell wrote:
"49mm TB flows 252 cfm
52mm TB flows 283 cfm
55mm TB flows 317 cfm
60mm TB flows 377 cfm
At 8200 RPM (Max RPM of a DOHC Neon with AF\X-Race V1 PCM) a 122 cubic inch engine will need 290 cfm at 100% volumetric effiency, using the formula ((Max RPM/2)*Displacement)/1728. Rule of thumb is to go 10% over because a naturally aspirated engine can go above 100% volumetric efficiency because of cam overlap, header design, etc. Go above that and you kill low end because of reduced velocity, go below that you starve the engine for air at top end. 110% is volumetric efficiency is 319 cfm."
Hope this helps!!
Marko!!
