Pics from my build
Old Aug 29, 2013 | 10:38 AM
  #81
gynosis's Avatar
Feels a bit sluggish on 0.3bar boost
Old Aug 31, 2013 | 01:23 AM
  #82
Jamesfredette's Avatar
Those are some really great pictures you have out there..are you done with your built or still in process.
Old Sep 2, 2013 | 04:21 AM
  #83
gynosis's Avatar
It's a continuing process, my Exedy stage 2 racing clutch is slipping after only 11 000km's. Ordering an ACT one next. Also ordered new Endless MX72 pads and the side shafts need a recon as the one is leaking grease by the boot.
Apart from that the car has been awesome!
Next up is LSD, AEM Series-2 and a bit more boost
Old Jan 12, 2014 | 05:57 PM
  #84
gynosis's Avatar
Hmmmm, not sure why I kept on saying I was getting an ACT clutch when I actually ordered a Clutch Masters clutch kit and flywheel...
The Endless MX-72's are awesome!
Next major update is happening in a month or two
Old Jan 17, 2014 | 11:21 AM
  #85
bana1988's Avatar
Where can I get the gauge pod you have?
Old Jan 23, 2014 | 01:45 PM
  #86
gynosis's Avatar
You asked me that on page 3...
Old Feb 15, 2014 | 03:45 PM
  #87
gynosis's Avatar
Strange, wonderful and rather expensive things are happening...stay tuned!
Old Feb 15, 2014 | 03:49 PM
  #88
TPColgett's Avatar
Woot! in for more deets! What's the info on the clutch/flywheel?
Old Feb 15, 2014 | 04:03 PM
  #89
gynosis's Avatar
Well one of the hold ups is the previous workshop managed to strip 4 of the 6 flywheel bolts. Picking up a new set from Honda on Monday. ARP was a little confused when trying to order a set from them for the Jazz...
The other hold up is one of my engine mounts is broken. Soooo I ordered a set of Innovative mounts (75a).
So the Jazz is here now for some much needed TLC...
Without giving too much away just yet it's getting a bit more than just maintenance
Old Feb 15, 2014 | 04:08 PM
  #90
TPColgett's Avatar
Ahh.... the Innovativemounts are NOT a simple . My trans mount had the wrong sized center shank, and the bracket for the passenger side just did not fit AT ALL. I ended up retrofitting the innovative bushing into the stock mount. Once I finally got them in there, SO worth it though!!!
Old Feb 21, 2014 | 09:24 AM
  #91
gynosis's Avatar
Thanks for the tips, will see how it goes, hopefully I'll have better luck.
They arrived so I should be getting the car back next week
Old Mar 20, 2014 | 07:43 PM
  #92
hehn's Avatar
Any updates on the mounts? I got a set for a good deal I only got the 60a though. They should be here in the next week.
Old Mar 21, 2014 | 10:49 AM
  #93
viperpit07's Avatar
good looking build man! sub'd
Old Mar 24, 2014 | 02:22 PM
  #94
gynosis's Avatar
The one mounting was off by 25mm, not sure how Innovative releases a mount with such a big difference to the OEM mounting points...So I kept the one OEM mount in.
Still waiting to get my car back...
Oh and thanks viperpit07
Old Mar 24, 2014 | 02:38 PM
  #95
TPColgett's Avatar
Let me guess, passenger side mount? Same issue I had...
You CAN modify to OEM passenger mount to use the harder bushing though, and I HIGHLY recommend it as having one "weak" OE mount will blow it out quick!
Old Apr 13, 2014 | 03:03 PM
  #96
gynosis's Avatar
Will keep an eye on that mount but I've been advised that all should be well.
The printer couldn't handle the dyno sheet, luckily all the important bits are legible :P. For reference, the initial line was when I dropped the car off. Pretty shocking I know.
2nd line (Red) was after the initial bugs were ironed out.
3rd line (Pink) is the final result on 0.6bar boost with adjusted timing and fueling where necessary. No detonation and MUCH smoother than before.
Old Apr 14, 2014 | 04:27 PM
  #97
JoshUK's Avatar
Love this build! What did you have to modify on the boomslang harness due to your car being SADM? I have a 1.3 idsi UKDM jazz that I want to turbo but can't find a suitable harness for a piggy back ecu so I was going to try modify the boomslang one
Any help would be much appreciated
Old Apr 16, 2014 | 06:46 AM
  #98
gynosis's Avatar
Thanks Not much was modified to the harness if any, it's quite a while ago so it's a bit difficult to remember. 'SADM' is more closely related to EUDM/JDM Jazz's/Fit's from what I've seen, so chances are it'll be a direct plug and play for you as well. If not the harness is all there and needs minor adjustment if necessary.
I wish the Hondata Flashpro was an option for me
Old Apr 29, 2014 | 06:54 AM
  #99
gynosis's Avatar
So I'll be doing my first official 400m and 1km event on the 10th. Will update with times and GoPro footage.
Old May 8, 2014 | 11:00 AM
  #100
gynosis's Avatar
In preparation for Saturday
