HPD Supercharger
Right now the weakest link is the modded "stock" rotating assembly, which put up with 65-67lbs/min @ 9250rpm and much higher boost (37-38psi) in the old car on a smaller turbo. That tune was not the most aggressive however, but the accel vs. weight numbers put it in the lower-mid 600s.
So it's already dead man walking. There's a proper shortblock being pieced together but the plan is to thrash this one until it quits. I can't imagine it would last much more than mid 600s for any considerable period of time.
Late last month we made 410whp @ 15psi without really trying in the new car.. fat AFR, weak timing, runs cut short to 7500, only got 3-4 pulls before running out of time that night, etc.
Excuses, excuses I know.. but there is a lot more left at the same boost with just some timing and rpm!
I got rescheduled again, but with any luck shes going back on the rollers 11/23 weather permitting to get more aggressive and start using the back half of the power band.
b15azn
10-13-2012 01:04 AM
da9r00d
49
01-06-2011 11:13 PM
F'it_ImFromTx
02-22-2008 05:27 PM
