2015 Honda Fit G3 Engine won't start once but in second it was all the times
Old May 30, 2024 | 07:15 AM
natural positive's Avatar
Pls let me explain summary ASAP i can.
My car 2015 Honda Fit G3 - After I changed key fob battary low to new one it won't start at once when press Start Engine but in second press ok . It was all the times almost 3 weeks.
Noted: i have an Idle stop / start A circle symbol it was showing dashboard very very occasion but it won't work this function since when i bought it.
No.1- What i did and Checked are - Starter Moter, Main Battary , Fuses in Fuses box , (reset already Motor rotor gear position sensor in gearbox) ,Behind Engine Start/stop button circuit, and another fuses under Steering that all are good conditions.
No. 2- What i did and Checked are- I tried with 3 varies of Diagnotic scan tools, Showing nothing fault error. But i tried with last scan tools it was showing Error code is
" temporay : B32A0 13 An open EDLC module power circuit". So i go and check EDLC where situated place , i check with Multimeter tool, it was showing 10.11 Volts (original volts is 16V).
For about function of EDLC it is showing under Hood with sticker i saw it that EDLC related parts " Starter Motor, contactor, BBC unit" even if you remove the 12V battery. # When working on EDLC moudule- related parts, use the EDLC module, Disconnect the negative terminal before starting work. Please check the service manual when working.
Need to check all cable wiring connectors with EDLC , right?
Noted: i have an Idle stop / start A circle symbol it was showing dashboard very very occasion and won't work this function . After changed key fob battary it was showing all the times (Idle stop/ Start A circle symbol) Twice press Engine Start/stop button. When it''s not showing at the time the Engine is directly start at once.
Our country have no Honda dealer support company .
Pls help and any suggetions from you. Thanks !
tinaxturner
Jun 9, 2024 08:58 AM
fatpinchincaves
Nov 28, 2023 10:49 AM
JB357
Feb 23, 2023 01:01 PM
JB357
Feb 23, 2023 04:33 AM
Helen
Jan 9, 2020 03:16 PM
