HID Upgrade Question
No, I did not install a LED bulb but I installed PIAA DENO6. PIAA DENO 6 is a daytime running lights from PIAA. It will always on when I turn on the ignition but it will be off when I turn on the headlights - low beams. However, the PIAA DENO 6 lights are on when I switch to high beam.
You can search for PIAA DENO on eBay or PIAA.com to see what it looks like.
Hey i want to install HID in my Fit 09, but i came up with this two:
HIDExtra.com - The Best Source for HID Xenon Light Conversion Kits H4 Hi/Lo-10000K Automobile Xenon HID Conversion Kit
HIDExtra.com - The Best Source for HID Xenon Light Conversion Kits H4 Bi-Xenon-10000K Automobile Xenon HID Conversion Kit
I got the site from this post:
https://www.fitfreak.net/forums/fit-...sion-pics.html
But I want to know what's the difference between Hi/Low and BiXenon? :S
Im thinking that in the post, chrisng was using the Hi/Low HID kit, cause he stated that it was only $60 (although the site now has them for $75...)
I'm ordering my HID kit this Monday and already pulled the fuse for the DRL's, I think its #17, so I don't expect any lights coming on the dash. I can't believe how cheap HIDS are now, amazing
They're cheap because people are finally starting to educate themselves on how poor quality these kits are, how much they reduce visibility, and scatter light into the eyes of oncoming drivers. Remember brighter isn't always better. Light waves coming out of a halogen filament act differently than that of a xenon arc light source. Reflector housing headlights are not meant to redirect xenon light. They are illegal, and cheap, for a reason.
And BTW, 10000K is WAY too high. You aren't getting any more useful light, only color. True white (and the most useful) is @ 4300K. Almost all factory HID systems are between 4300-4500K.
What the OP also needs to know is that HID is a strain on the stock wiring, which was designed for standard lighting. Igniting HID capsules pulls a TON of current, and can cook a factory wiring loom in about a year if not properly configured.
I have my HID kit ordered and didn't want to go over 6k because it looks like crap IMO, as well as many others for that matter. A while back my buddy and I both had Contours, mine had a set of custom quad projectors with HIDS rated at 4300k, while his were 6000k w/o projectors. Now I'll say this, in the morning drive out of Detroit to head down to the Dragon, while driving next to each other, mine looked like Halogens compared to his system. I know brighter isn't better as the blue color from the higher than 6000k system just gets absorbed into the ground when its foul weather out and also looks really bad.
Speaking of projectors, I hope someone comes out with a nice set of projectors for our cars that are mostly black inside, it will be a great day when that happens!
Your a bit confused. Projectors are just a reflective bowl that focuses the light, not a whole headlight. You can put projectors from other cars and put it into your stock headlight, and paint it black, like so:
Its called retrofitting, and it is WAY better than buying those cheap china made headlights that come with generic projectors built in. These projectors do not focus light correctly and decrease visibility. Retrofit is cheaper and has OEM quality. The picture I posted are my headlights, with Infini FX35 bi-xenon projectors. Read more about retrofitting here:
https://www.fitfreak.net/forums/fit-...rofitting.html
Here are the headlights on my car:
To add a bit more, you can buy some high performance plug-n-play bixenon projectors for $135 that uses the hid kit bulbs. You get the performance of a true projector hid kit and the "cheap" replacement parts. If you are going with a pnp hid kit, might as well throw them into a pnp projector as well. Then your light will actually be usable and not dangerous to others.
Im not talking about the garbage g1 and g3 projectors either..
Or you can spend $25 more and get quality bi-xenon projectors like the FX35.
The Retrofit Source (U.S.) - HID Projector Retrofit Kits, Retrofit and HID Componenents, Projectors Lens, Wiring Harnesses, Shrouds and more!
Here is the FXR. The beams are wide due to me cutting the reflector uneven
Here is the H1 Mini. The beams are centered correctly because no cutting is needed
The only noticeable difference is the amount of color difference (fxr has better color and a tiny bit more width)
Now here's the question, are you going to be making these for other members?
You give me too much credit lol. I wish I had the abilities of performing such a clean retrofit. But I had these done. Just talk to Rich over at www.hidillusionz.com and tell him I sent ya. It will cost a pretty penny, but the fit, finish, and quality is all flawless. No condensation, no misalignment, no rattle, no flickering. Remember all the parts in my headlights are OEM. Check out his site and his work, he is a professional.
09, 2007, 2009, accord, circuit, drl, fit, headlights, hid, hidextracom, honda, installation, kit, loation, upgrade
