custom headlights...
Old Dec 30, 2010 | 01:24 AM
ohanahuichubbz's Avatar
i recently did changed my signal bulbs to switchback led bulb (stays on white, then switches to amber when turn signal is on) it requires a double filament socket which our fits do not have so i did some custom modding...i used a universal double filament socket and tapped it to the existing socket & parking wire. i am positive that i am the 1st fit to do this mod. here are some pics i took earlier before it started to rain.
here is just driving light switched on (parking + ccfl angeleyes + led strip + signal)
the new signal (switch back led bulb...requires custom socket modding)
cclf angeleye + parking 5smd led t10 bulb
further back pic
projectors on
passenger
driver
cutoff (im parked at an angle)
vid of the switchback
Old Dec 31, 2010 | 05:46 AM
90crxfreak's Avatar
what is all that extra light above your cut off?
Old Jan 1, 2011 | 02:28 AM
its cuz i didnt paint the reflectors black..so they light is bouncing off causing the light...
Old Apr 16, 2012 | 01:19 AM
smithbrother88's Avatar
Oh no it's glare you better watch before someone here flames ya!
Old May 2, 2012 | 11:31 AM
xonexlifex's Avatar
Hahahaha aint that true. Lets see how long it take before that happeneds
Old May 12, 2012 | 06:25 PM
jnesselroad's Avatar
Heres a little trick I learned. If you don't wanna paint your reflectors, but don't want the glare, you can take aluminum tape, fold it on itself (basically sticky part to sticky part) and put it around the back of your projector, where the light is venting out causing the glare and it'll get rid of that. But ya, you should take care of the glare. Kinda defeats the purpose of the projector.
Old May 12, 2012 | 06:39 PM
BlueBoogers's Avatar
Needs more accessory lighting
Old May 12, 2012 | 07:39 PM
solbrothers's Avatar
mods: can we ban the OP for making a retrofit with glare above the cutoff?
ohanahuichubbz
16
Feb 13, 2023 04:15 PM
SxExCx
Apr 2, 2015 06:58 PM
Pandahh
SoCal Classifieds
Jul 21, 2014 02:52 PM
AtticusFit
480
Mar 19, 2012 06:07 AM
Rubba Burna
Feb 23, 2010 10:47 PM
