LED Replacement Headlamp Bulbs
Old Aug 17, 2019 | 04:55 PM
  #81
Bassguitarist1985's Avatar
Got it, so bait and switch for more money it sounds. Oh well
Old Aug 19, 2019 | 11:38 AM
  #82
silverrose12's Avatar
so basically, unless the car comes with LED from the factory, its not really worth to replace halogens with LED ..
=S
Old Aug 19, 2019 | 11:43 AM
  #83
2Rismo2's Avatar
Originally Posted by ercdvs
chiming in again since I have become dissapointed with my replacement LED bulbs ( These ) DRL are fine, no flicker, but i feel the projected brightness isnt out as far as I want, and the close in fill isnt as good as I want them to be. I have really noticed it a lot more driving in places where there are no streetlights and hardly any other cars next to me that seem to enhance my cars lighting.
I probably can adjust them, but I am scared to raise the cutoff any higher for fear of blinding oncoming traffic. I light even just pick up bright halogens to compare to make sure im not being dense ..
I have these same bulbs and like their performance. It's way better than the stock ones. I drive a few miles with no street lights in a rural area and I don't even need to use the high beam anymore as these illuminate so much better. Today I drove my wife's Odyssey and I can remember why I swapped to the LED bulbs and I will be buying her some LED bulbs since the winter is coming.
Old Aug 23, 2019 | 05:11 PM
  #84
nomenclator's Avatar
Anyone who has installed any of the superbrightleds LED lamps that have an 9 volt to 32 volt spec, can you tell me how bright the highbeam filaments were when in DRL mode? Were they the same brightness as when configured as normal highbeams, or did the PWM system manage to make them a little dimmer?
Old Oct 2, 2019 | 06:25 PM
  #85
wistlo's Avatar
How did you get the steering wheel on the right side? Is there a kit for that?
I am actually here investigating OEM replacements after coming too close—much too close—to a deer while driving on a rural US Interstate with low-beams into oncoming traffic. The Fit does poorly on the IIHS Headlight test (along with most current models, it turns out).
Reading through here, it seems there is no obvious solution that is legal, long-life, reasonable cost, a warm/near stock color, does not throw error codes, but also provides more light in the distance than OEM.
Old Dec 25, 2020 | 05:51 AM
  #86
dll932's Avatar
My solution, at least for now, was to install a pair of driving lights that use halogen H3's. The additional light helps when I need it on really dark roads. I have them aimed like high beams so I shut them off when there's oncoming traffic. I also leave the stock fogs on all the time, so can see the edges of the road but also so I can be seen (same reason I have a rear fog.
Old Dec 30, 2020 | 03:31 PM
  #87
The obvious solution is to require deer to wear reflective clothing when galavanting along the road at night.
Old Dec 31, 2020 | 06:47 PM
  #88
dll932's Avatar
That would help.
Old Mar 23, 2021 | 07:44 PM
  #89
Metman Metman's Avatar
2007 fit with new led headlights
installed by my service station. Now the daytime running lights do not work. Is there a fix, or do I drive with headlights on?
Old Mar 23, 2021 | 08:24 PM
  #90
woof's Avatar
You can get pulled over and get a warning or even a ticket for that. Used to happen to me with a previous car but since it was so old it didn't have daytime lights they'd wave me off once they realized that. Still a nuisance getting pulled over though.
Yeah you can probably drive with your low beams but you'll probably forget to turn them off when you get out of the car. In fact you'll probably start to forget to turn them on when you get into the car. .......
As far as getting daytime running lights working with LEDs no idea. You should have done that research before putting in the LEDs.
Old Mar 23, 2021 | 08:32 PM
  #91
thanks...i went by the advice of my service mechanic. They got a kit and installed it. I wondered about a workaround.
Old Mar 23, 2021 | 08:42 PM
  #92
woof's Avatar
Ask your mechanic if the kit they installed has a feature to allow daytime running lights because its kind of useless if it doesn't.
Old Apr 24, 2023 | 01:06 PM
  #93
Soconfused's Avatar
Per your post. (From @Uncle Gary)
Uncle Gary is offline
I ordered the 'superbrightled's' and they are as you say. Simple install, dust shields fit and DRL's still work. VERY HAPPY with these. Thanks for the post!
sneefy
13
Nov 29, 2018 12:12 PM
TaubBaer
Nov 16, 2018 07:39 PM
XXXG-00W0
Nov 25, 2014 01:42 AM
R18-Power
Jul 23, 2011 11:40 AM
Cachupin
Jul 5, 2010 10:10 PM
