those with 4ch amps
Old Sep 20, 2008 | 11:28 AM
martymcfly's Avatar
And you get a "free" seat warmer and "floor" warmer with this design. Works great in cold weather I bet j/k
Old Sep 20, 2008 | 11:35 AM
mrwilli1's Avatar
I NEVER have had to turn the heater on! The amps generate more than enough heat for the coldest day in California.
Old Sep 20, 2008 | 02:46 PM
feared's Avatar
can you still fold down the seats for utility mode?
Old Sep 28, 2008 | 02:03 PM
SIN696's Avatar
I mounted my PDX on the hump between the rear seats. Cant see it when looking in the car.
Old Oct 9, 2008 | 02:04 PM
koolkevin1107's Avatar
utility mode is when you lower the seat back cushion so it sits on the floor and so u have a huge cargo area. Like this:
It looks good at how tall mode and regular seating works good, but i don't think it'll work in utility mode without the amp hitting the floor.
BUMP for an answer from mrwilli1
Old Oct 10, 2008 | 12:20 AM
mrwilli1's Avatar
The magic seats work in all modes without any issues.....
Old Oct 15, 2008 | 12:31 PM
madhartigan's Avatar
Hey mrwilli1.
The pictures you posted on the first page are not showing up.
Is there anyway you could either link them up again or point me to somewhere that I could view them?
Thanks!!
Old Oct 15, 2008 | 01:14 PM
mrwilli1's Avatar
Originally Posted by madhartigan
Hey mrwilli1.
Thanks!!
Old Nov 17, 2008 | 03:23 AM
bhad's Avatar
Here's mine
Old Nov 17, 2008 | 05:13 AM
feared's Avatar
forgot to ask this when this thread was started... how well do the pdx's fit under the front seats?
Old Nov 17, 2008 | 01:43 PM
mrwilli1's Avatar
Unfortunately, They don't!
Old Nov 18, 2008 | 05:21 PM
  #32
feared's Avatar
thanks for the info, given me a lot of ideas for my stealth install.
Old Nov 18, 2008 | 10:39 PM
  #33
feared's Avatar
hey, just to confirm, the pdx fits /w the seats down? i just checked the clearance between the seat and the center bump... there's not much clearance...
Old Nov 19, 2008 | 12:16 PM
  #34
mrwilli1's Avatar
As long as you mount them as above, they work fine and the Magic Seats function properly...
Old Nov 19, 2008 | 09:32 PM
  #35
feared's Avatar
i founded my seat down to utility mode to check clearance and i can barely fit my hand there...
Old Jan 31, 2009 | 11:17 PM
  #36
Daemione's Avatar
I'm looking to upgrade the sound system in my '07, and stumbled on this thread when looking for ideas on amplifier mounting . . .
Sorry, but this is impossible. When folded flat, the seats are completely flush to the rear floor & center hump.
I don't want any of my hard work visible from outside the car, so for amp mounting, it looks like I'm gonna have to deal with the limited space available under the front seats. Anyone happen to know off-hand how the seats are mounted? Would it possible to slide some washers between the rails & the floorboards for an extra half inch or so of vertical space?
Old Feb 1, 2009 | 02:58 PM
  #37
Daemione's Avatar
Checked this out today for myself - 3 of the 4 mount bolts are parallel to the floorboards, so adding washers would be possible on those corners. The 4th one (one of the front bolts) is on an angle, though. So it'd be possible to raise the rear of the seat some for a little extra clearance, but I don't know if that would help much, since the floor slopes upwards to the front of the seat to begin with. It's the front of the seat where more vertical space would be handy. I suppose something could be fabricated that chances the mount angle of that one corner, but I'm not sure it's worth the effort.
In taking some other measurements, I don't think I could get even a small amp tucked under the front seats as much as I'd like, and maintain full range of motion front & back. And with someone sitting in the rear seat, I still want some foot room available. I want to avoid having passengers feet smashed up into the amplifier, which is what my current situation is in the Prelude. In the Prelude it hasn't been an issue since the rear seats are pretty vestigial, and noone wants to sit back there.
So it looks like I'll be mounting an amp in the spare tire well. With a small 4-channel, there should still be enough volume available for the custom enclosure I'm planning.
Old Feb 2, 2009 | 01:38 AM
  #38
feared's Avatar
you can fit jl hd amps under the seats
nicco
Jan 25, 2015 05:03 PM
blythe
15
Aug 24, 2011 09:52 PM
ej20i
Apr 26, 2010 05:12 AM
accordguyintake
Jan 26, 2010 02:54 PM
sterVin
Jan 24, 2009 07:57 PM
