Alignment Question
Old Apr 19, 2016 | 06:34 PM
jhn's Avatar
jhn
Add SPC 81260 camber bolts in the top position and add -1.5 camber, set toe to 0. Get a 4 wheel base alignment just to get an idea what all the wheels are doing. It's possible your rear toe will be out of spec. The geometry of the beam on a lowered Fit can cause the toe in to increase, as well as how the tech person pulls the car onto the table. The compliance bushings can give a false reading so don't sweat a slightly out of spec rear alignment as the torsion beam tends to correct itself in the bushings. There's no easy way to change rear alignment settings.
I found -1.7 in front actually helped me get a more even tire wear. Rear stock will be in the -1.3 to -1.6 or so.
Old Apr 19, 2016 | 06:35 PM
jhn's Avatar
jhn
Toe in or toe out is what accelerates tire wear. -2.0 or less camber will be negligible.
Old Apr 19, 2016 | 06:45 PM
apexanimal's Avatar
aim for about -1 in the front, and feel free to do about -.05* toe out in the front... it'll help it turn in.
check the tire wear before and after about 2k and adjust as needed
Old Apr 19, 2016 | 07:16 PM
dwtaylorpdx's Avatar
From factory owners manual.. (Just so its in here.. )
Toe-in ---------------
Front 0.0 in (0 mm)
Rear 0.10 in (2.5 mm)
Camber ---------------
Front 0°
Rear -1°30’
Caster ---------------
Front 3°45’
whitefitsport
Oct 2, 2018 10:54 PM
Nvillegas
Jan 9, 2014 01:05 AM
gnarlyj3rick
Apr 16, 2013 01:33 AM
flushge8
Hawaii Community
41
Feb 17, 2010 01:25 AM
diedwater
Jun 26, 2009 09:45 PM
