DIY: GD Rear Disc Brake Conversion
Old Sep 1, 2021 | 10:54 AM
  #81
Miguel Sanchez's Avatar
Jazz/fit gd specific rear disc brake assembly
Thank you so much for this information, however for wher im from, we have a varient of honda just that comes with rear disc from factory, dyou think that would bolt on to non disc variants like i have? Planning to do the conversion as well. Thank you
Old Sep 1, 2021 | 07:06 PM
  #82
Elpapas's Avatar
make sure that for the rear the donet car has the same rear axel set up and you should be find
Old Mar 27, 2023 | 01:14 PM
  #83
jim13p's Avatar
Emergency brake cables
Where did you find the emergency brake cables? I looked on Rock Auto for the recommended Honda Acura Legend 1987 that is in the parts list from apexanimal. I assume this was where you got your info?
jim13p
Old Mar 28, 2023 | 05:06 PM
  #84
GAFIT's Avatar
jim13p
A better alternative exists now. You can use a FastBrakes parking brake cable adapters and use your factory cables. Not sure if they are listed on their Site. May need to call or email them.
https://www.fastbrakes.com/default.asp
Old Mar 28, 2023 | 05:16 PM
  #85
jim13p's Avatar
Great help THANK YOU! ! I will check it out..
Jim
Old Apr 16, 2023 | 10:04 PM
  #86
Baumbauer's Avatar
do these fit the 97 integra calipers as well? The kits I see available are for rsx/civic si rotors.
Old Apr 17, 2023 | 05:53 PM
  #87
jim13p's Avatar
Well the parts I found where on amazon. Raybestos BC94043 and BC94044 professional grade parking brake cable. The same car is what is called out for the disc mod and much cheaper. Also the brake lines should be the same from this car for the Fit. The front calipers are the same from the 1987 Acura Legend 2 door base model as the 1997 so that being said it makes sense that the cables and hoses will be the same.
Jim13P
Old Apr 17, 2023 | 06:32 PM
  #88
Baumbauer's Avatar
Jim13P
yeah I have the 97 integra calipers and rotors installed. Its just those 87 legend cables are out of stock everywhere. Ive even tried japan.
Old Apr 18, 2023 | 12:52 PM
  #89
jim13p's Avatar
Maybe a trip to a junk yard ?
It FITs Me
May 2, 2026 11:52 PM
apexanimal
99
Apr 12, 2015 09:04 AM
intiaz_k
Jul 27, 2011 01:49 AM
siownschu
36
Feb 15, 2008 06:14 PM
Deivioncrx
Jan 9, 2007 03:15 AM
