HFP 16" wheels questions and answers
Old Jul 13, 2007 | 04:17 PM
  #121
mducrow@mac.com's Avatar
Same factory honda ones.
Old Jul 14, 2007 | 04:34 PM
  #122
thelate1's Avatar
anyone? i know people have these.....
Old Jul 16, 2007 | 09:05 AM
  #123
pocketrocket's Avatar
HFP Wheel
Are the HFP Wheels 7" width?
Thanks
Old Jul 16, 2007 | 10:12 AM
  #124
grouser's Avatar
mine will be here in a few days,,will look for you
Old Jul 16, 2007 | 11:18 AM
  #125
a call to tirerack answered my question. they are 7 inches... thank you though! Had to make sure I ordered the right tire size.
Old Jul 16, 2007 | 09:54 PM
  #126
thelate1's Avatar
no one?????
Old Jul 16, 2007 | 11:27 PM
  #127
thelate1's Avatar
Originally Posted by siccmonkey
Trying to get a feel for how it would look, cant make up my mind on wheels. and dont want ANY rubbing issues, about to give up and grab the HFP's or some volks eheh so post up some pics if ya got em thanks
i was hoping for pics as well.......nhbp lowered, with hfp rims...
Old Jul 17, 2007 | 11:31 PM
  #128
davevm's Avatar
Originally Posted by ciburri
Uncle Dickie,
if you are handy and don't mind working out some elbow grease, you can paint them yourself for under $60-70! Key is in the prep. It won't peal off if you sand them down and take your time.
If not, you may as well powdercoat them. It is more durable than paint.
I painted mine on the Fit and powdercoated OZ's on my CRX 15 years ago.
Fit's are holding up great so far.
Which ever route you take, good luck and post some pics!
nice job on the wheels!!! the "stock" stockers don't look so good now that there r so many on the road.... the paint job really hardens the lines, makes the car look tough...i might have saved some dough if i had thought of painting mine!
Old Jul 18, 2007 | 02:44 AM
  #129
ciburri's Avatar
Thanks man! You can still do it for winter time when you are saving your custom wheels. If you still have them. No reason not to look good even in snow! LOL!
I got HFP wheel centercaps and painted the "H" in red to match. I am just trying to get a hold of small piece of real carbon fiber sheet with UV coating to put over the cap before I re-apply the red "H" over them. Once I get it all done I will update my post for "OEM wheel in black w/red rim edge".
I am tempted to get HFP wheels and "fix" them up as well, but I just can't justify the expense even at $106/ea plus tires.
Old Jul 21, 2007 | 03:09 AM
  #130
davevm's Avatar
you know, i do use my stocks for winter...snow sucks unless it is on a mountainl!! gotta ask, what brand/type of paint did you use?
thanks
Old Jul 21, 2007 | 04:14 AM
  #131
ciburri's Avatar
thanks
I used DupliColor wheel paint. I wonted saten finish, so I did not shoot them with clear coat. For winter application I would recomend you clear coat them couple of coats. Everything you need to know is in this tread:
https://www.fitfreak.net/forums/fit-...-rim-edge.html
BTW, I finished my center caps with carbon fiber and raised honda logo in red. It got too dark, so I will shoot some pics in the morning and update my tread.
If you do your wheels post some pics will you? I am curious to see them in different paterns and colors.
Old Jul 24, 2007 | 10:32 PM
  #132
grouser's Avatar
Just recieved my HFP 16's and I must say I'm very happy with them. For only 106 bucks the wheels are of very high quality and the finish was flawless. Gonna look good on the MR/MT,,when it shows up next week!!!It's still on the boat right now AAAAAAAAAARRRRRRRRRRRGGGGAAAHHHHHH!!!!!!!!!!!!!!
Old Jul 28, 2007 | 02:38 PM
  #133
larryfuturefit's Avatar
Wanting new rims
Hello all I have a stock base fit and was wanting to upgrade to the 16" rims. I've seen it is recommended to use 205/45/16 tires but I already have a set of 205/40/16 tires. If I use the slightly smaller tires will that mess up the ride or handling?
Thanks Larry
Old Jul 28, 2007 | 03:55 PM
  #134
CarDemon's Avatar
Senior Member
I've seen it is recommended to use 205/45/16 tires but I already have a set of 205/40/16 tires. If I use the slightly smaller tires will that mess up the ride or handling?Thanks Larry
Your speedometer will read 3.5% too fast eg. at 60mph you will actually be @ 57.9mph. You also incrementally add kilometers to your car at a faster rate eg. OEM 867 wheel revolutions/mile compared to 898 rev/mile due to the smaller sidewall.
Other than that...your ride will not be messed up just a very miniscule and negligible harsher or rougher ride due to the lower side wall, but not much since 40series and 45series are pretty close.
Tire size calculator
Old Jul 28, 2007 | 11:15 PM
  #135
boyetssilverfit's Avatar
indeed,i used to have 16 inch wheels on my fit with a kumho exta tires 205/40/16 set up no problem at all,
Old Aug 4, 2007 | 02:05 PM
  #136
thanks CarDemon and boyetssilverfit
Thanks for your replys. I decided against the rims even though they look real nice I primarily want to keep good gas mileage.
Old Aug 5, 2007 | 12:25 AM
  #137
grouser's Avatar
I just ran the first tank of gas the dealer put in it and I'm running the 16's. Got 34.7 mpg
Old Aug 16, 2007 | 06:09 AM
  #138
fitdc's Avatar
Don't know about the speedo issue but-- a 15in radius gives you a circ of 707in--91in greater than the 14in radius tire. A 16in tire has a circ of 804in--so go figure.
Old Nov 7, 2007 | 01:48 AM
  #139
FIT4ELE's Avatar
16" HFP's
would like to know where you purchased HFPs?
Old Dec 30, 2008 | 09:27 PM
  #140
SFactor2's Avatar
From: Negative Repland (exiled by fragile ego's and "can't handle the truth" babies) LMFAO ;P
Originally Posted by t-bone
Yes you are absolutely right.
I didn't include tire width into my example to make it easier to understand that increasing wheel size will not affect your car's rolling diameter and therefore your car's speedometer much. It's negligible.
But to be thorough one must include the tire width in their calculations.
not negligible to a cop's radar/laser!!!!
that 1 kph/mph (could put u in a higher penalty bracket) could cost u thousands in the long run (insurance)
