Sponsored by:
Sponsored by: CARiD
CVT Cooler
Old Jan 31, 2021 | 05:10 PM
tyrtill's Avatar
Short answer is I think it would
The part number for the cvt "warmer" is different between the two vehicles but I think this may have to do with hose routing
25560-5T0-003
This is for 2015-2020 Fits
25560-R3W-003
This is for the 2014-2020Civics and 2016-2020 HRVs
https://www.hondaautomotiveparts.com...tf-25560r3w003
https://www.aliexpress.com/item/4000825894719.html
This is the best I could do for comparison of the back side. The reddish area is the fit and the underlying grey is the civic part so it does look like the plate would work as all the bits that need to line up do. Since the O-rings are shared between vehicles we can be sure that the scaling is correct.
Here is an EBAY 2016 Cooler Kit that seems like it would work
https://www.ebay.com/itm/2016-Honda-....c100752.m1982
Another interesting note is that the Civics/HRVS/CRVs in other countries have OEM CVT coolers. I could not find an OEM foreign fit cooler plate. This part is for 2017,18,19 for sure
https://www.parts-honda.uk/honda-car.../ATM17/2/30842
Part Number 27900-5Y8-Y00
I also found this
https://www.sodecaok.com/index.php?m...ucts_id=211972
Old Feb 1, 2021 | 12:37 PM
David James's Avatar
Great! Thanks for all the info @tyrtill. I'm going to get the ebay one you linked (looks like it's the same as the vivd racing one but cheaper). I'll let you know how goes.
Old Feb 8, 2021 | 10:01 PM
Gave it a shot, and the answer is....NOPE! Does not fit. The screw holes don't line up.
Old Feb 9, 2021 | 09:22 AM
tyrtill's Avatar
Are they off just a tiny bit? That’s disappointing.
Old Feb 9, 2021 | 04:29 PM
The bottom hole is off by quite a bit. If you look at the adapter in @JingJangJoe 's post, the bottom hole angles in the opposite direction of the one in the 2016+ Honda Civic kit. The top holes are only off by a little bit though.
Old Feb 12, 2021 | 06:58 AM
tyrtill's Avatar
That’s strange.
It almost looks like it would fit if the plate was flipped over.
I wonder if one of the parts pictures I had was mirrored before I downloaded it.
Old Jul 23, 2022 | 06:23 AM
GA fit guy's Avatar
https://m.aliexpress.com/i/225580072...site4itemAdapt
I found this, anyone have any experience dealing with this website?
Old May 13, 2023 | 03:37 AM
Mr.GK5's Avatar
Congrats on the successful installation. Would you mind sharing where you get the kit from and the connection route as well? I have the same problem with my CVT. Had to change fluids at 16,000km because it feels very sluggish although it's almost brand new. Car drives much smoother now which is what it's supposed to
austinrebel
Feb 11, 2025 08:25 AM
victorgarage
Dec 5, 2022 02:22 AM
Liljpw16
Sep 30, 2019 03:27 PM
dave92029
May 4, 2014 02:08 PM
