Sponsored by:
Sponsored by: CARiD
Silicone radiator hose kits, opinions?
Old Feb 24, 2008 | 07:45 PM
tonyd3773's Avatar
Smile
Originally Posted by Mud_Bone
thanks tonyd 3773. thanks everyone so far that has given opinions
No Prob...GOOD LUCK
tonyd3773
Old Feb 26, 2008 | 03:28 AM
ciburri's Avatar
If you have the money to burn power to you.
FYI, I had 1980 Accord with a horizontal crack the length of the radiator and car was not overheating!
My CRX is 18 years old and still has original hoses! I changed coolant twice a year since new and regularly inspected hoses. No problems! I have no deposits in the cooling system at all!
Hey it is a Honda! Have you ever heard of a Honda with an overheating problem?! LOL!
I also installed oil cooler on the CRX and ended up removing it. Cooling system is so efficient that extra cooling creates negative effect on my CRX. Unlike civics from late 90's, CRX radiator runs full width between headlights. ECU increases the rev limit at the right temperature. It would cut me off under well under 7K while properly hot allowed about 7900 rpm.
Now with a chip without rev limiter and Crane Cams ignition set up at 9,500 rpm this sucker screams like superbike in the canyons. My best man is a biker and he gets a kick out of hearing it each time.
Old Mar 10, 2008 | 04:12 PM
07fitsport's Avatar
wonder how these hold up..are they good or not...how hard to replace..looki like maybe lower is hardest to replace
okey0
Dec 10, 2018 02:45 PM
tacostand
Feb 18, 2015 04:47 AM
Paul56
Jul 25, 2011 05:44 PM
Java^FiT
19
Apr 4, 2011 08:00 PM
Shora
Dec 17, 2009 03:01 PM
