overheating
Old Feb 18, 2020 | 05:14 PM
Daryl Sands's Avatar
overheating
2006 FIT with 1.5 overheating,blowing anti-freeze out overflow.
Still doing after ...
Head Gasket/Machined head,new water pump and thermostat while apart.?
Any Ideas?
Old Feb 19, 2020 | 11:32 AM
Action Jackson's Avatar
What was replaced?
Was the cooling system properly "burped" to get rid of air?
Old Feb 20, 2020 | 04:49 PM
macbuddy's Avatar
Could be a radiator issue
I had a similar issue on a 1974 Dodge. The problem turned out to be a clogged radiator. Sediment and debris had blocked the core of radiator.
Mine was cleared by having it “rodded out.” I am not sure if this technique can be used on a GD3 radiator though.
Old Mar 13, 2020 | 01:11 AM
john21031's Avatar
Why ask here? Go back to whoever put you a head gasket. Apparently they failed miserably. Change that, go to a mechanic instead.
dlogvine
Feb 2, 2020 07:00 PM
d3vin
Nov 21, 2012 09:49 PM
im the fit
15
Jan 29, 2010 09:27 PM
mmdir2005@yahoo.com
Oct 11, 2005 11:36 PM
Rocky
May 22, 2005 10:16 PM
