Fuzzy Camera Display on my 2016 EX
Old Apr 7, 2020 | 04:06 AM
McDanielSan's Avatar
Exclamation Fuzzy Camera Display on my 2016 EX
Howdy y'all! I'm encountering a slight problem with the backup camera and right-hand lane camera on my Fit... the footage from the cameras is VERY fuzzy. Tried carefully cleaning the camera lenses, and there's still a good amount of pixels and static. The infotainment screen in the Fit works completely fine, just not the cameras. The lines showing my direction of travel still appear when I am in reverse, but the picture itself looks dreadful. Any technicians here that can help me DIY my way out of this issue?
Old Apr 7, 2020 | 11:19 PM
Action Jackson's Avatar
From what I've encountered. You can't fix the focus. I screwed up the lanewatch lines alignment and all I found out was that the lines can be aligned. Not the picture. You can't angle the view either from the side or rear (unless you start shimming it).
When I switched to a HD resolution display head unit, the picture quality immediately went up. So for me, it was the not so great resolution of the stock head unit that gives you the not so great resolution from the cameras. I put 3M clear protection on the lens once I got my car, so the camera resolution went down a bit.
If the picture quality is truly dreadful, then to the dealer you might have to go.
HondaFan75
Feb 25, 2019 10:44 AM
QuiGonQuinn
Aug 31, 2018 07:52 AM
SilverEX15
Dec 16, 2017 05:46 PM
kellyjoy
Mar 19, 2015 07:10 AM
ADVphotography
Oct 27, 2014 11:25 AM
