HF Jack Stands Recalled
Old May 20, 2020 | 12:58 AM
GolNat's Avatar
Harbor freight has issued a recall on 2 of their jack stand models. If you own them stop using them and return them to the nearest store for a refund.
https://www.thedrive.com/news/33572/...denly-collapse
Old May 20, 2020 | 08:53 PM
cojaro's Avatar
There's a reason they're known as Hazard Fraught.
Old May 21, 2020 | 03:54 PM
NWCH's Avatar
Ya I never buy any of their cheap tools for this very reason.
Old May 21, 2020 | 05:33 PM
Alco RS-1's Avatar
Thank you for the heads up GolNat. I didn't know about this and informed my brothers. I guess it's why one of them calls HF Bottom Of The Harbor Freight.
Hopefully my NAPA stands are okay. I bought them 15 years ago, the only set I could find with a wide beefy saddle that would securely support my pick-up truck frame. The pawl arrangement looks sound, with good locking depth.
Old May 21, 2020 | 10:02 PM
Brain Champagne's Avatar
I use ramps when I change the oil but a few weeks ago I cut up some 2X6s so that the next time I drive up onto the ramps I can stack the lumber under the car so if a ramp fails the car won't drop.
Old May 22, 2020 | 03:53 PM
GolNat's Avatar
Yeah I always use ramps when I can.
Not all HF stuff is bad. I have several of their tools including their floor jack that is very nice. Many of the stuff they carry is the same as GearWrench, Eastwood, or Lowes/HD brand just painted a different color.
I watched a video of the problem stands and if mine were like that I would have not used them. You could see that it was not latching properly.
Always important to do a good shakedown once the car is lifted also. If I have the car up on 4 stands I'll do a 4 corner shake test.
Old Jul 7, 2020 | 10:15 PM
Jazu's Avatar
Replacement stands are now also recalled
Now if you read the Road &Track article and link, HFs wording may lead to believe that potentially some of their 2011-2020 Jacks Stands might have a defect. They list the model numbers back to 2011 on this link and say that you can even take those in for a refund- no replacement.
https://www.harborfreight.com/js-det...8,894,925&uid=
Old Jul 8, 2020 | 02:38 AM
knope's Avatar
I still have my eye on one of their hydraulic jacks... If some thing as simple as a stand failed, how much faith should i put in the complex lifty thing?
Old Jul 8, 2020 | 03:04 AM
GolNat's Avatar
I have their low profile jack and it has been great. Hydraulic jack is only for lifting and not meant to be worked under so I never put too much faith into them.
Old Jul 8, 2020 | 05:03 PM
Jazu's Avatar
I have the HF hydraulic lift as well - their 3T low profile version from 2019. I would never trust a hydraulic lift that didn't have lockouts/pins to prevent it from falling. HF's lowest cost bidder made that hydraulic bit to just pass requirements.
I only use the lift to move things up - then jack stand the snot out of the car.
I wouldn't doubt that HF will re-review parts for defects and find issue with certain hydraulic lifts - FM GLobal or their insurance will require them to step up efforts or pay 50% more insurange premiums now.
Old Sep 29, 2020 | 09:25 PM
dll932's Avatar
uRabbit
Sep 8, 2019 06:32 PM
SilverEX15
Sep 26, 2017 08:55 PM
trashercan
Sep 24, 2017 05:46 PM
dstahnke
May 3, 2012 10:14 PM
mozarwasagenius
Apr 22, 2009 10:10 AM
