Opinions on air conditioning
Old Jan 11, 2022 | 04:29 AM
RD36's Avatar
It's parasitic it robs the engine of performance or lack of performance. Wish there was a way to have air con without draining the engine.
Old Jan 11, 2022 | 01:44 PM
woof's Avatar
So, you want something ....for nothing?
Old Jan 11, 2022 | 02:15 PM
knope's Avatar
Lightbulb
^lol
​​​​​​​You'd probably need to run the ac-compressor off an electric motor to achieve that. I'd be curious to see the results.
Old Jan 12, 2022 | 12:29 AM
TnTkr's Avatar
Originally Posted by knope
^lol
It's still power taken from the engine crankshaft. It'd need to be something like 2 kW electric motor, which has quite remarkable seize and weight, and it'd also require remarkably bigger alternator in order to produce that electric power. It's much less efficient than having a bigger compressor.
Old Jan 12, 2022 | 10:59 AM
mobby_6kl's Avatar
I think many modern cars do electric A/C, especially if they have start/stop or hybrid systems. The advantage there is they can use the recovered energy to run the AC while the engine is off.
Old Jan 13, 2022 | 10:50 AM
Red 05's Avatar
We build the Mercedes GLE and GLS here, only the "mild" hybrid systems and up will do AC without the engine. Takes a 48V system to run the accessories on ours
Old Jan 17, 2022 | 05:05 PM
rerod's Avatar
Air conditioning? What air conditioning?
Old Jun 9, 2022 | 03:15 PM
dogbite's Avatar
The AC seems more than sufficient for my desert Southwest use. The climb out of Cameron AZ up to Flagstaff is a few thousand feet of elevation change, 108 in Cameron. 90s in Flagstaff. AC worked just fine.
Old Jun 13, 2022 | 07:13 PM
knope's Avatar
Post
mmm that makes sense... it is a compressor after all..
i find myself turning the blue/red knob more to the middle after about 10mins at highway speeds.
Old Jun 14, 2022 | 10:24 AM
BMWguy22's Avatar
+1
I find it really gets chilly when on the highway as well.
I attribute it to the increased airflow.
Old Jul 11, 2022 | 12:10 PM
Hopalongcasualty's Avatar
Mine either, I'm in Dallas TX; yesterday it was 108 F (Heat indexed)
newcarsmell16
Dec 31, 2015 10:18 PM
hjohnson40_79
Dec 14, 2010 12:57 PM
charlottefit
Sep 11, 2007 07:53 AM
JKR
Aug 28, 2006 09:20 PM
hqly
Jul 31, 2006 02:51 AM
